Old 11-05-2017, 04:49 PM
maniago's Avatar
maniago maniago is offline
You installed fire transfer material.
Search "firewall insulation".
Ah I see. Not book. I dont necessarily agree with your conclusions, but I understand your line of reasoning. Thanks for the clarification.
Mani
MustangII (FoldingWing) "Finishing up": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI,WhiskeyCompass
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Jan2019
Old 11-05-2017, 05:39 PM
Ron B. Ron B. is offline
Try testing it with samples of your products, then you will know. That's what Dan has done with numerous products (and most likely your product) and shared his results with us. Thanks Dan.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 11-05-2017, 06:12 PM
Bavafa Bavafa is offline
Where did you source your Ti from?
Thanks for the great write up.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-06-2017, 04:52 AM
sritchie sritchie is offline
Hey Mehrdad,
It's from Titanium Goat, a lightweight backpacking supply company. Check out the top of the first post for the direct product link.
Old 11-06-2017, 05:11 AM
titanium needs pressure to help it burn. when exposed to normal pressure under the cowl it should not burn.
Old 11-06-2017, 08:59 AM
Originally Posted by SMO View Post
I have 185 hours on mine. I used stainless tape to seal up the stainless foil encasing ceramic fiber. I had a major oil exposure event at about the 60 hour mark - left the dipstick in the hangar - that resulted in hot oil everywhere including the firewall (quick turn around and land when I noticed oil seeping out the oil filler door on take off). The stainless tape is holding up fine.
Thanks for the info.
Do you recall specifically what stainless tape you used (or the supplier)?
Scott McDaniels
Hubbard, Oregon
Old 11-06-2017, 11:28 AM
DanH's Avatar
DanH DanH is offline
Don't really want stainless tape for this application. Melting is desirable to vent the overlap seam.
Take a look at Polyken 339:
http://www.herculesindustries.com/si...cs/25pstul.pdf
or Polyken 345SW:
http://catalog.berryglobal.com/catal...5SW_092915.pdf
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-06-2017, 12:30 PM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
This makes sense but what about the adhesive? Wouldn't the adhesive "melt" or soften and allow off gassing in either case?
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Fuselage
www.DarinAnderson.com
2019 donation sent!
Old 11-06-2017, 01:08 PM
DanH's Avatar
Fair point. Probably yes.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-06-2017, 01:32 PM
Dorfie Dorfie is offline
Default Belly fireproofing
What size area would you or did you cover for fireproofing the belly? Specifically:
Wider than the cowl outlet at the front? Full width of belly?
How far back from cowl outlet did you insulate?
Did you keep it the same width front to back, or taper towards the rear?
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
2019 dues paid with a smile
