Old 09-24-2018, 11:31 AM
snopercod's Avatar
Couldn't you use a bent piece of wire or small Allen wrench to spread the JB Weld around the inside? If it were me, I'd do that then cover the hole with tape (Peel-Ply would be great!) to keep the JB Weld from draining out. I'd also mask off the area around the hole to keep the JB Weld from sticking to the leading edge when the tape spreads it out. (I'm assuming the leading edge is facing down.)
(2019 dues paid)
Old 09-27-2018, 07:39 AM
togaflyer togaflyer is offline
Tape a slightly larger area around the holes and slot with packing tape and then a strip of electric tape. This allows some build up tha can be sanded down. Press in the JB weld as mentioned. Make sure you don’t sand the JB weld off back to the aluminum. Just float it where you see a smooth transition, leaving a little material covering the holes and slot. Don’t forget each wing has the slots.
Old 10-09-2018, 04:44 PM
bob888 bob888 is offline
Pop rivets plus paint = barely noticeable
Old 10-09-2018, 05:13 PM
MElstien MElstien is offline
Default Filling stall warning holes in QB wing
I don't have an answer for doing it with the tank attached.
I pulled the tanks to test them and while off I filled the right wing rivet holes with a soft rivets. I had them for fiberglass tip work. Easy. It will require a little bit of filler when painted.
I also installed the stall warning kit on the left wing: Belt and suspenders.
Happy Building,
Michael
Builders Blog http://elstien.us/wordpress/
Northern NJ
RV-10 Builder
Tail Kit delivered 6-2013
Started building April 2014
Empennage completed
QB Wing and Fuse Delivered December 2015
Finishing QB wings on September 2018
Moved to Port Orange FL November 2018
Project moved to Port Orange Feb 2019
Dues Paid through 2019
Old 10-09-2018, 08:07 PM
N908RV's Avatar
N908RV N908RV is offline
Default NAS1097 AD3 is a good solution
Use the very small oops rivets to do it instead that will avoid the flat spot. After a little sanding and scotchbrite on mine you can barely tell they are there: NAS1097 AD3
Rob Brooks
EAA Tech Counselor
Warrenton, VA
RV-8, QB completed, flown 750hrs and sold
http://www.taildraggersinc.com/pages...RV_flying.html
RV-7, SB completed and flying Phase 2
http://www.mykitlog.com/N908rv/
Old 10-09-2018, 10:03 PM
lr172 lr172 is online now
I tried this today. It is only a #40 hole and it didn't seem like the dental pick was getting much in there to work with and the squeegee'ing didn't seem to do it either. In the end I filled it as best I could then left a large blob over the hole. I then put on masking tape and pulled tight. I am hoping that forced a bit more in there and gravity spread it around internally. We'll see tomorrow after it sets up. If it's loose, I'll pull the tanks.
N64LR
RV-10 in progress
