Old 11-25-2018, 09:00 AM
Hwood Hwood is offline
Default Rudder Pedal Travel
Am about to install my ground adjustable rudder pedals (-8) and have found that there is some clearance issues with the independent brake reservoirs hitting the firewall when the rudder pedals are mounted on the full forward position. The solution is pretty straightforward....just mount them farther back. My question is this......what kind of rudder pedal travel distance should I plan for once they are installed and connected to the rudder?
Anyone have a idea? Thanks in advance!
Hwood
N469SH / "Crazy Woman" (sold)
Working on Another -8
Exempt but paid
Old 11-25-2018, 09:17 AM
rv8ch rv8ch is offline
Default reservoirs
I saw the same thing and switched back to the normal method of having the brake reservoir connected with tubing. I am sure I don't need that much travel, but if someone with longer legs wanted to fly, the pedals might hit the FW.
Mickey Coggins
http://rv8.ch
Old 11-25-2018, 10:52 AM
Carl Froehlich's Avatar
Try adjusting the rudder cable length (the firewall anchors).
BTW - the RV-8 I helped with has independently reservoirs on the master cylinders. I found them to be a real PITA to check and fill. Not recommended.
Old 11-25-2018, 11:03 AM
Thanks guys...of course, going back to one reservoir is an option and has been considered.
Hwood
Exempt but paid
