Old 02-19-2018, 06:53 PM
Kupde Kupde is offline
Default Getting to the airport
Asking for help on how to get to the airport in Late March or early April. Well Iím planning on moving the project from my garage in Brandon FL to Tampa Executive Iíve read many threads and Iím finding it difficult to find a trailer thatís wide enough for the RV-10. Also it sounds like some builders have called for a car tow truck but Iím concerned that it may take a while to get the whole thing rigged safely so Iím not sure if a tow truck will be interested in spending that much time. Iím open to any suggestions and just want to have an option available in 4 or 5 weeks. Any thoughts are welcome.
Old 02-19-2018, 07:02 PM
Do you have a friend who has equipment - backhoe, cat, etc? Their trailers should be wide enough. You can rig an 8' wide with a 2x12 to carry the plane if necessary. Make sure you have friends there to help. The more the better.
Have fun with it and remember this in not the last time you will go to the airport so don't try to take everything at once.
rockwoodrv9a
Williamston MI
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 02-19-2018, 07:03 PM
Originally Posted by Kupde View Post
Asking for help on how to get to the airport in Late March or early April. Well I’m planning on moving the project from my garage in Brandon FL to Tampa Executive I’ve read many threads and I’m finding it difficult to find a trailer that’s wide enough for the RV-10. Also it sounds like some builders have called for a car tow truck but I’m concerned that it may take a while to get the whole thing rigged safely so I’m not sure if a tow truck will be interested in spending that much time. I’m open to any suggestions and just want to have an option available in 4 or 5 weeks. Any thoughts are welcome.
Move the airplane on a Saturday or Sunday morning. Be sure to give them your specific vehicle requirements (width in particular). The driver will be sitting around bored that time of day, and will likely be intrigued with your project. Even better, he'll be happy he doesn't have to crawl down into a swamp or ditch to retrieve a car.
Instead, he'll be on solid ground just trying to winch the thing onto the trailer and rig it. There are better riggers around than me, but with the RV-6, we chocked it and used several straps attached to the gear legs and to hard points on the truck to secure it. Wasn't that hard.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-19-2018, 07:13 PM
aturner's Avatar
aturner aturner is offline
We used a standard tilt bed tow truck and the -10 fit fine. Did not take long to load and strap down. The mover was a pilot and friend, which helped, but it wasnít difficult. I think most drivers would enjoy doing something different for a change.
-Andy Turner
RV-10 N784JC
Old 02-19-2018, 07:18 PM
Tomcat RV4 Tomcat RV4 is offline
ABSOLUTELY NOTHING SAFER OR SANER THAN FLATBED TOW TRUCK,
MOST will give good price because attention to move will get attention to their
business ! Tom
Tomcat RV4
dues paid and worth every penny
Life is uncertain -Eat desert first !
U F O Member since Dec 2017
Old 02-19-2018, 07:20 PM
YellowJacket RV9 YellowJacket RV9 is offline
I can heartily recommend Clearwater Towing. They moved my 9A from Clearwater to ZPH without any issue whatsoever. And the cost was unbelievablely low. I believe the driver was Carlos.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 02-19-2018, 08:29 PM
9GT's Avatar
9GT 9GT is offline
You can not beat a rollback deck flatbed. Make sure the deck is wide enough for the -10. The first truck he came out with had rails on the side that were about 6" high for tie-offs. Not wide enough! He had to go back and get the true flat deck. You can see the tires are just barely fully on the deck. Did it on a low traffic Sunday morning. Under $100.
[IMG]IMG_0027 by David C, on Flickr[/IMG]
David C.
Howell, MI
RV-9A: Under Construction.
RV-10: Completed 12/29/2013 SOLD 08/23/2016
"Donor Exempt" but donated through Dec. 2019
Old 02-19-2018, 10:57 PM
I had a nearby construction equipment rental place that rented me a tilt-bed truck. I took a tape measure, only one of their trucks had a wide enough bed. I made two trips to the airport (main fuselage on one trip, wings on another.)
Old 02-20-2018, 05:28 AM
mturnerb mturnerb is offline
You may want to check these folks out: https://www.barnstormers.com/ad_mana...php?ID=1340990 or https://dreamworxaviation.com/
The owner was badly injured in a crash late 2016 and is back working now. No idea how competitive they might be price-wise but since they're close to me I'll be in touch when the time comes. (And not far from you).
Reference: https://www.beechtalk.com/forums/vie...?f=41&t=146279
Turner Billingsley
RV-14A FLYING!!
Old 02-20-2018, 06:47 AM
AviatorJ AviatorJ is offline
I recently moved the wings and horizontal stabilizer to the airport. I rented a 17' box truck from uhaul. This gives you about 15' of usable floor space, the 17' includes the part above the cabin. Anyhow with the wingtips on it barely fit. Just used straps to secure the wing cradles and HS to the sides of the truck.
I haven't moved the fuselage and stuff and won't plan to until probably this summer. My plan though is to use a friends roll back as described above. That's the safest way I can think of to move it.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
