Old 01-21-2019, 08:17 PM
rnewcomb7797 rnewcomb7797 is offline
Default elevator fairing countersinking
I need to countersink the elevator fairing tips. Any recommendations on how to keep the countersink cage flush with the fairing since there is that slight flange just to the side of the hole?
Ron
#140220
RV 14A tail kit done
QB wings in the crate
QB fuselage done
finish kit in progress
Old 01-21-2019, 11:22 PM
lr172 lr172 is offline
Eirther free hand it or make a plate from .125 and drill a 1/2" or 5/8" hole in it. Space the hole edge to piece edge to accomodate you joggle. 063 migth be enough depending upon the joggle height.
learning to free hand a countersink is an important skill. Its not that hard.
N64LR
RV-10 in progress
Old 01-22-2019, 04:34 AM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Countersink
+1 for what Larry said about free hand countersinking. I used a 100 degree deburr bit to countersink all my fiberglass. Rather easy once you get the sequence down.
Jon
RV-14A - N122X
http://www.mykitlog.com/mulde35d
Empennage & Wings Complete
Awaiting Fuselage Delivery
Research Always
Old 01-22-2019, 08:14 AM
kiljoy's Avatar
kiljoy kiljoy is offline
I did mine by hand as the force of pushing the countersink cage down on mine was bending the fiberglass. I wound up using my drill with countersink bit while using two fingers on either side from the bottom to support the fiberglass.
Dues paid (2019)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - Somewhere in Ch. 30
YouTube Build Channel
Old 01-22-2019, 02:06 PM
MED MED is offline
As an alternative to using a drill, I put my bare countersink bit in my electric screwdriver. The slow speed made it very easy to control depth.
MED
140236
N435MD
Old 01-22-2019, 05:22 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
I like doing it freehand as others have mentioned, but with the countersink in an extension. It's easier to handle...
https://www.aircraftspruce.com/catal...llThreaded.php
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-22-2019, 06:59 PM
Breezy Breezy is offline
Ron,
The quick way is to free hand the countersink. Use a scrap and practice, the bits can grab with little pressure so get a feel for it. A sharp bit requires very little pressure. Use a very low speed on fiberglass.
I often free hand in aluminum as well if only needing to do one or two holes.
A ready extension for threaded bits is a cable turnbuckle center. The clockwise end is a match to the bit threads, also drill bits. If you have the equipment lathe the unused end for easier chucking to a drill.
Good luck!
Breezy
First offense RV-8; N594WR; 80594 (time served)
ECI TITAN IOX 360 A1A9N, G3X
Repeat Offender: 83137 (Flying 10/16)
N837DW; Superior IO 360; G3X Touch.
Exceptional Aircraft Award, Sun N Fun 2017; Best Homebuilt, Mid-Eastern Regional Fly-in 2017.
One More Time: 140359, -14 in process, IO-390 (Maybe)
KHAO (Hogan Field)
