Old 12-19-2017, 07:19 AM
snopercod's Avatar
Default Basic Med?
I switched to Basic Med this year, and the "certificate" is attached to my logbook, which I don't carry in the plane. That info is online, though, so the FAA (or anyone) could check. I carry my Repairman's Certificate in the plane.
(2018 dues paid)
Old 12-19-2017, 11:42 AM
Since the repairmans certificate is only needed for the annual condition inspection, there seems little reason to carry it around with you.
Old 12-19-2017, 01:43 PM
airguy's Avatar
airguy airguy is offline
Unless you need to do maintenance on the road somewhere, and a "do-gooder" tries to interfere...
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 360hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 12-19-2017, 01:50 PM
Mel's Avatar
Mel Mel is online now
Repairman certificate has nothing to do with maintenance.
Only required for the condition inspection.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-19-2017, 02:25 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
OK, well, you may know that. I may know that. The local A&P who is irate enough to come over while you are pulling a major component off of your plane may not. It may at least be enough to get someone to pay attention to what reasons you may have for doing something (s)he may think is a violation. Just thinking out loud here.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 12-19-2017, 03:18 PM
Mel's Avatar
If an FAA type is about to cite you for anything, simply ask him to show you the regulation he is citing you for. He is required to do that.
There is no regulation anywhere that prohibits anyone doing maintenance on an experimental amateur-built aircraft.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-19-2017, 05:14 PM
snopercod's Avatar
So would it be "legal" for me to...say...change a propeller on my aircraft without a Repairman's Certificate?
(2018 dues paid)
Old 12-19-2017, 05:24 PM
Mel's Avatar
Yep! Just follow you operating limitations. You must place the aircraft back into phase I for testing if the replacement is not the same make and model as the one removed.
And submit a new 8130-6 to FAA if changing of a fixed pitch from or to a controllable propeller.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-19-2017, 06:41 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Originally Posted by dabney View Post
Anybody know for sure about shrinking and laminating, or does it depend on who you ask in the FAA??
The easiest solution is to just keep your required documents in a zip-loc bag, and keep that in a pocket in the plane. It protects them and leaves them easily accessible for inspection. Airworthiness, registration, and any not often used cheat sheets for avionics are in mine.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on the canopy and wiring
84CX Reserved
Old 12-19-2017, 07:46 PM
RV8iator's Avatar
RV8iator RV8iator is offline
Default Beat this dog to death..
When will experimental pilots get this right? You can do anything, anytime, anywhere except the condition inspection without a repairman certificate.
Jerry "Widget" Morris
RV 8, N8JL, 2700+ hours
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018.
I just wish I could afford to live the way I do
