Old 01-17-2019, 10:04 AM
CJ in EP CJ in EP is offline
Default Garmin G3X Day/Night VFR Panel - RV-9A
Exciting progress in the shop last night, got the panel mounted and most of the harnesses secured. Still a lot to complete before I can really turn the system on, but the back up battery at least let me turn the screens on to play for a little while.
A few pictures of the panel, installation of the remote components on the sub panel, and the harnesses:
Mounting of the remote boxes on the sub panel. Nothing will be out of reach for future servicing:
A closer look at the GTX-45R install:
Left side sub panel:
Right side sub panel:
Sub panel center:
Cockpit view:
Cockpit view:
Chris Hrabe
Eden Prairie, MN
RV-9A
Finishing Engine / Starting Panel
Old 01-17-2019, 10:24 AM
Zero4Zulu Zero4Zulu is offline
Very nice work Chris!
Steve S.
Rebuilding RV6A
Scio, OR
EAA Ch. 292
Old 01-17-2019, 06:50 PM
Fhuber's Avatar
Fhuber Fhuber is offline
Wow Chris! Your workmanship is outstanding and your panel looks great.
Frank Huber
RV-7A flying
2019 dues paid
F Huber
RV-7A flying
2019 Dues paid
Old 01-17-2019, 08:51 PM
dreed dreed is offline
Wow, beautiful and clean. Great looking work!
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
Waiting for updated nose dragger mount/gear-
2018 and 2019 VAF dues paid
Old 01-18-2019, 11:18 AM
drtgraves drtgraves is offline
Chris, I'm interested in the left side of your panel. I cant quite see the keyed switch that you used, What is that? Also, what switch are you using for your ignition testing? Where did you find those? Thanks. T
EyeDoc
14-499 221RV reserved
Paid
Old 01-18-2019, 12:50 PM
terrye terrye is offline
Originally Posted by Walt View Post
Happy RV9 owner leaves with this new panel
Garmin G3X with GTN750
Walt,
Beautiful panel. The Aft Engine Control bracket (push pull throttle, prop, mixture) does not look like the F-746 supplied with the kit. Did you just round the corners, or is this an aftermarket part?
Terry Edwards
RV-9A (Fuselage)
2019/2020 VAF Contribution Sent
Old 01-18-2019, 01:27 PM
Default Here's a closer look.
Hey Doc,
The key switch I believe to be a simple SPST that only serves to enable the master switch. Not much for security, mostly just to prevent an accident if someone without any knowledge decided to jump in and start pressing buttons.
The mag switches are 3-position, the upper "test" position has spring return to the "on" position, and to engage the "off" you have to pull the toggle while rocking it downward.
The round, silver button on the lower left is a momentary push button for engine start.
Stein built my panel, they'll be able to hook you up with whatever you need.
Here's a better picture:
Chris Hrabe
Eden Prairie, MN
RV-9A
Old 01-18-2019, 04:51 PM
Walt's Avatar
Walt Walt is offline
Originally Posted by terrye View Post
Walt,
The throttle mount is from Stein, it's milled from a chunk of aluminum.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs, New Titan IO-370, Bendix Mags
Old 01-18-2019, 05:53 PM
BillL BillL is offline
I have one that looks like that from Stein and it is bent and welded to that shape. It is older and possibly made differently.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 01-18-2019, 09:51 PM
PNLBLDR PNLBLDR is offline
Default Throttle Brackets
We used to cut/bend/weld/sand these, but have since changed to milling out of bar stock. Both 9 and 12 versions available!
Nick Millard
Operations manager, SteinAir, Inc.
