Old 12-03-2019, 12:30 PM
Sam Buchanan's Avatar
Sam Buchanan Sam Buchanan is online now
been here awhile
Originally Posted by Steve Melton View Post
if you stay with the flattened tube you may consider 3/8 inconel 600 or 625 tubing. stronger, but not as much elongation capability when it's smashed. you may need to heat it progressive as it's smashed.
....or just use 3/8" steel brake line....readily available.....easy to swage....only takes a couple of minutes.....and last a long time......
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 12-05-2019, 02:01 PM
Good results so far with stock Vans arrangement. One thing I did to reduce possibility of slippage was to make 4-5 slits with a Dremel cut-off wheel, perpendicular to length of tube. Gives the rubber something to bite into.
Doug
RV-9A "slider"
Flew to Osh in 2017, 2018 & 2019!
Tail number N427DK
Donation made for 2020
