Old 02-20-2018, 02:42 PM
n4322b n4322b is offline
Default VA136 / VA139 - Anyone know the difference ?
VA136 is the fuel injection fuel line ($199) and VA139 is given as fuel supply line ($128).
Apart from length, is there any difference in the spec of the hose ? such as high pressure from the fuel pump ?
Ian
Old 02-20-2018, 03:35 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Ian
I do not have the plans with me at work but I think it goes something like this:
VA-136 = 23" X 3/8" (fire-sleeved) IO fuel hose from engine fuel pump to servo
VA-139 = 16.5" X 3/8" (fire-sleeved) from FW connection to engine fuel pump (or maybe from servo to spider)
Same hose. I'll can double check when I get home unless someone beats me to it.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 02-20-2018, 06:23 PM
The VA136 is a straight/90* -6 firesleeved teflon hose, 23 inches.
The VA139 is a straight /straight -6 firesleeved teflon hose, 16 inches. Vans has a Stratoflex shop make them.
Tom
Ridgeland, SC
Old 02-21-2018, 04:16 AM
thanks for that. I was concerned in case it was a different pressure rating.
#Cheers
Ian
Old 02-21-2018, 07:08 AM
Nope----rated at 3000 psi working pressure.
Tom
Ridgeland, SC
