No transmit on one button
Stan Bahrns
Active Member
My left transmit does not transmit however the right one works fine. the left button works as the transmit light on the radio comes on when pressed & I get the click in the headset. I can use the headset on the right side & the right button & everything works fine. There must be something somewhere that differentiates the 2 different buttons & headsets & wonder where or what that is. If anyone has any ideas I sure would like to know.
Thanks in advance
Stan Bahrns
RV12 N618B 135 hrs
Effingham, ILL
Mic
Sounds like the mic connections on the headset plugin.
The centre ring should be the mic audio. Check the wires. If PTT light up then the connector that hits tip of mic jack is good. Other one is common.
Make sure the insulating washers are in place to isolate the metal panel.
