Old 04-19-2017, 10:11 AM
Draker's Avatar
Draker Draker is offline
Question Alodine or primer for the tank attach countersinks
Started on my RV-7A wings recently and the first task is to drill those big ol' countersinks on the spar for the tank attach screws. The instructions say to prime the freely drilled aluminum which is what I've done, but I've seen build logs where builders are using alodine on them instead. Is there a big benefit to doing it this way, or just personal preference? Don't want to start a primer war if that's all it is. Just wondering if it's worth considering cleaning out the primer and applying alodine instead, which wouldn't take too long.
By the way, coming straight from the gentle hand-holding empennage instructions, the wings feel like boot camp: "Welcome to the wings. NOW DROP AND GIVE ME 150 NUTPLATES!"
Old 04-21-2017, 07:48 AM
rv7charlie rv7charlie is online now
Alodine is technically lighter (though I doubt you could measure the difference there), and primer is a lot quicker & easier, unless you're using one of those one-step alodine pens to 'color' the places.
I certainly wouldn't change it if you've already primed.
If you think it's boot camp now, it will be a vaguely defined mission soon....
Charlie
Old 04-21-2017, 08:32 AM
rapid_ascent rapid_ascent is offline
It's much simpler to just mask and prime the area.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 04-21-2017, 08:42 AM
Auburntsts's Avatar
Default +1
This. I primed those CSKs and would do it that way again if I had to.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-21-2017, 09:08 AM
jibby212 jibby212 is offline
Alodine pen and epoxy primer with a Q tip for me but I live on the coast of Florida so corrosion scares the **** out of me.
Old 04-21-2017, 09:10 AM
wirejock's Avatar
wirejock wirejock is offline
Default Countersinks
Which do you have? Alodine pen, use it. Primer? Spray some in a paper cup and apply with a Q-tip.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/27/2018. Plus a little extra.
Disclaimer
Old 04-21-2017, 03:05 PM
Draker's Avatar
Thanks for the advice, all. I did the "cup of primer + q-tip" method and will probably just leave it be.
