EFii ignition noise solution
UPDATED 03/08/2020 - My apologies for this really really late update. WAY over due. You can disregard the original post but I will leave it intact (to my embarrassment) in case there is any value in it for other readers. This faraday cage set up out lined below that I so painstakingly constructed and installed was unnecessary as Robert Paisley pointed out. My issue was that I was not able to get rid of the arching I was getting at the spark plug terminals with the screw on aluminum terminals. Once I went to a steel solid spark terminal spark plug, everything went quiet and stayed quiet. I've been using NGK BR8ES 3961 plugs with good results. Nothing fancy and inexpensive. Thanks again to Robert Paisley for being so patient with me through all of this. Great great customer support.
It would seem that I have resolved my ignition noise issue with my EFii dual ignition installation. My installation consists of the dual ignition but not the electronic fuel injection. My coil packs are mounted on the firewall and the engine is a Lycoming IO360A3B6D. My apologies in advance for the tardiness of this post since the fix was installed back in July of this year (2015), but it has given me the opportunity to put some hours on this fix and prove it's worth and to make note of an issue that popped up shortly (5-10 hours) after the initial flights that might have gone unaddressed had I posted too soon. Also, please try to excuse my ignorance if so noted. I'm a learning creature. A work in progress so to speak.
What has worked for me involves a bit of work, but the results were really worth it for me.I had times that on my takeoff roll on rwy 20, where the the ATC control tower signal is probably the weakest for me. I couldn't hear the towers transmissions due to the volume of the immense ignition noise in my headset. With brand new (note that I say "brand new" spark plugs. I'll get to this later) spark plugs, it's now whisper quiet. Also, I'm no Einstein and couldn't have done this on my own without the help from several of my Los Alamos brain-iack friends.
In a nut shell, here's what seems to be happening. The harness going to the coils and the coil packs themselves are radiating RF like a Banshee. The fix was to fit a large 3/4" copper braid shielding on the entire length of the harness going to the coil packs and to fabricate a faraday cage for each of the coil packs. See photos. There's a ink at the bottom for the photos if I did it right.
With the harness shielding, I only shielded the harness firewall forward with very good results. If I were doing it again with a fresh installation, I might shield the harness all the way back to the ECU(s), although it has proven itself not to be necessary. Firewall forward is working great for me. The 3/4" copper braid is the minimum size needed to slip over those large connectors. If you have a way of removing and then re-installing the pins in the connectors, you could definitely use a smaller size braid and save some weight. The stuff is pretty heavy. I made pigtails and quick disconnects to continue the shielding on the short harness runs for the coil packs. You see a little of this at the top of one of the photos. A pigtail was also used to ground the shielding to my firewall.
The faraday cage was fabricated from a very fine 80 or 100 copper screen. I'm not sure what the numbers (80 or 100) really mean other than it's really fine stuff. Although the screen seems to allow air to circulate easy enough through it, I placed a blast tube on each of the coil packs to aide in the cooling. The packs are mounted on my firewall (see photos). At the corner of each of the cages I soldered leads with quick disconnects that of course go to ground. The copper screen cages are delicate and very light and were made with a flange at the base used for mounting. I just used aluminum tape and made sure that the firewall surface and the flange were really clean. It's holding up very well. The copper screen solders very easily, but you might want to practice a little before attempting the finished product if you're not experienced with working with solder. I used a lot of soldering paste to help keep the solder flowing.
A note in regard to my approach to fabricating the cages. I made a cardboard (thin cardboard like cereal boxes or poster board) template and found that I could make it in one piece, and by keeping one of the corners unfastened, I could slip it over the coil pack if I held my mouth just so. I fabricated a crude hinge from very small copper tubbing for the open corner of the cage which allows me to close it up once I have it fit in place. The cages had to be fit after the coils were mounted on the firewall so had to be designed to be removable, which is good for the inevitable unexpected maintenance issues that always seem to pop up.
I tested this all with brand new spark plugs and was in awe of just how quiet my radio had become. It was really impressive. Weak signals still got the static that you get from those situations, but there was very little if any ignition noise. Then my bubble burst after about 5 or 10 hours or so. The ignition noise returned little by little. It was in no way as obnoxious as it was before I did all of the shielding, but it was very noticeable and irritating after all of that work. I figured that it had to be the spark plugs. Maybe the resistors breaking down??? I really don't know. The only thing that I knew to try was to reduce the spark plug gap down to .025" as recommended by Robert (Robert Paisley from EFii). That seems to do the trick. It may not be quite as quiet as the brand new plugs, but it really does quiet things down. I think that it's the last little detail needed to keep the noise at bay, at least on my installation.
I hope that this helpful to anyone who is suffering the same issues. It sure worked for me.
photos here
http://imgur.com/a/ro3MB
