Go Back   VAF Forums > Main > Safety
Old 04-05-2020, 03:09 PM
pjc's Avatar
pjc pjc is offline
Default Thanks.
Excellent Aviation Decision Making and superb write up.
A bureaucracy on the ground is always preferable to a fire in the air.
Thanks for sharing, Iím smarter (and safer) now.
Peter
Vans RV6 flying
SZD 48-2 flying
2018, 19, 20 Dues paid
Old 04-05-2020, 07:17 PM
ArlingtonRV ArlingtonRV is offline
Default Similar, but Opposite Situation.
Well done.
I had a similar incident in my Air Force days, but I wasn't the pilot, I was the mechanic on the ground.
I worked Transient Alert at Bitburg AB, Germany in the late 80's/ early 90's. One of our responsibilities was to assist emergency response of non-base assigned aircraft, since we had more knowledge of them than the regular folks.
One day we got a call from the tower that there was in in-flight emergency (IFE) inbound, nature of the emergency unknown, aircraft type F-35. None of us had any idea what an F-35 was (previous century remember). We were pulling out Jane's big book, nothing. Finally we looked up and saw a bright yellow Bonanza pulling off the runway. I said "oh, F-35 Bonanza, OK".
Since I was the only one with any GA experience, and most of the guys were afraid of propellers, I was handed the job. I went out and parked him in front of the office. Our office was at the base of the tower, right next to the fire department, so it seemed like a good place.
About the time I got him parked the Security Police (SP) showed up wanting to ask him a few questions. He was still in the airplane fiddling with the controls. I got his attention and had him shut it down. As I secured the airplane (no wheel pants, so our usual chocks worked fine and I improvised with the ground wire) I asked what the problem was.
He said he could get full manifold pressure, but only about 1,800 RPM. I immediately figured it was the propeller governor. We went around to the front of the plane and sure enough, the governor case was cracked and leaking oil.
About this time the SPs were wanting to have a chat with the pilot. They asked a few questions and escorted him to base operations, which is directly above our office. About the only requirement put on him was that he had to be escorted at all times.
He was a ferry pilot ferrying a brand new Bonanza from the factory to the Lufthansa pilot school. He called Lufthansa and in about 2 hours there was another Bonanza on the ramp with a mechanic and a new propeller governor. They swapped it out, did a test run that went just fine and then both Bonanzas took off together. Total time on the ground about 3 hours.
I asked the pilot how he ended up at Bitburg and not somewhere else and he said that when he started to lose RPM and it was clear that he could not maintain altitude he looked down and saw a runway. He figured out that it was a military base, but he declared an emergency and was cleared to land.
All in all, it provided a break in the tedium of daily activities without causing any real problems for any one. The one big lesson that I took away from that incident is that that if you have a problem, declare an emergency and don't worry about who owns that runway until you are safely down and stopped.
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 04-05-2020, 08:17 PM
catmandu's Avatar
catmandu catmandu is offline
When I got back into GA, flying traffic in 172's, the thing I missed most was being able to flip through mishap reports on the message board in the Ready Room (physical paper messages, kids! Yes, I am INDEED that old), so that I could learn from other's experiences. It took me a while, but I eventually learned there were 'virtual' reports out there on this here interwebs.
You, my friend (he really is, folks!), have done the RV community a great service with your write up. You are a credit to the . . . crud, this is not a FITREP, I'll stop typing now.
Mike C.
Sierra Nevada
RV-6A bought flying
Old 04-06-2020, 08:25 AM
506DC 506DC is offline
Default Been there done that....
I finished building my RV-4 in 1997 and been flying her ever since. It's been a 23 year love affair. The first engine she sported was a first run new engine out of an old Mooney.
After about five years of flying, I noticed a small puddle of oil on the ground that had rolled down the cowling. I carefully inspected the engine and found no oil leaks but was worried something was wrong. My mistake was that I did not physically tighten all the nuts and bolts on the engine. So, I just kept a good watch on the leak that kept leaking but never got worse so I ASSumed that my engine with about 1200 hours since factory new was not new anymore.
My son was in the military and he wanted me to fly his girl friend to San Diego from Fresno for a weekend visit. The weather over the whole LA and San Diego area was solid overcast so I filed an IFR flight plan and set out to San Diego.
I still was worried about the leak so kept monitoring the oil pressure. My course took me over Bakersfield at about 10K feet when the oil pressure started to fluctuate. I immediately knew the problem was loss of oil. I pulled the engine to idle, cancelled my flight plan and spiraled down to Bakersfield Muni. About half way down, my prop went into high RPM as a result of the low oil pressure. I landed and taxied to the ramp with the engine sounding normal. I got out of the airplane with the girl looking like this was a normal event. She told me later that this happens with the farm tractors all the time. You have got to love those farm girls. Oil was all over the left side of the fuselage. I removed the cowl to find the B nut on the #2 cylinder gone and the oil drain line disconnected. I do not ever remember removing the oil line when installing the engine.
We tightened the nut, put in new oil, and cleaned the plane. I checked all the other nuts and bolts which all were tight and after an extensive run up and full power climb to altitude, we continued our trip to San Diego. Lucky for us, the entire coastal area was solid overcast all the way to San Diego. It would have been an interesting IFR approach with a frozen up engine had the incident happened while in the LA basin.
I flew the plane another 500 hours and traded it for new XP-360 engine.
Another incident happened just last year in my C-170B. I had just completed a Fresno County Sheriff Air Squadron practice SAR over the high Sierras at altitudes as high as 11k and of course, very rough terrain. We flew back to Chandler, debriefed, refueled headed back to the Sierra Sky Park (E79) where I live. We got about 700 feet when a valve boss broke on the right rear cylinder.
The engine vibrated valiantly and I made a 180 turn back to the airport for an emergency landing. I reduced power to about 2K RPM to perhaps ease the vibration. The engine kept running rough but smoothed out enough where I was tempted enough to make another 180 turn back to E79 so I could get my plane safely in my hanger which was only 5 minutes away over some densely populated areas. I then thought to myself, "This is really stupid Dale, you are right at an airport" so I made again another 180 and landed at Chandler. Turns out that I could have easily make it to E79 but it would have been the wrong decision.
I was going to put a sign on my plane that read “God is my copilot” but after seeing a sign in a store window that said “Protected by angels” decided it would prevent people from asking my wife if she really was GOD.
Dale
RV-4 Fastback completed in 1997
C-170B
Transition training
Taildragger instructor
CFII MEI
Last edited by 506DC : 04-06-2020 at 08:50 AM. Reason: said Bakersfield meant San Diego
Old 04-07-2020, 09:11 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Glad that you and the plane came out ok.
Just one question. You mentioned that you turned on the electric pump when you were finishing your approach.
Originally Posted by RhinoDrvr View Post
.... The Lycoming O-360 coughed to life one cylinder at a time ....
... I reached over, and pushed the mixture up. The lever didn’t move; it was already fully forward. I snapped on the electric boost pump,
I have it on my Before Landing Checklist in case of a go around, is your engine set up different or am I adding something is it not needed in the RV-8 / 0-360 combination? Thanks.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building a FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 04-07-2020, 01:09 PM
RhinoDrvr RhinoDrvr is offline
P135PD,
Good catch. I definitely use the pump on takeoff to backup the engine driven pump.
On landing I typically turn it on entering the pattern VFR (be that at the initial, or turning into the downwind.
I wasn't using it for the practice approaches although, I probably should have been. Having not doing much IFR work in the -8, my habit patterns aren't fully developed yet. I'll probably start working it into my habits to turn the pump on at the FAF.
Here's my understanding; it's never required in normal operation. It's always a backup in case of engine driven pump failure...the idea is that if the engine driven pump fails, the electric pump will takeover seamlessly and you won't know until you turn off the electric pump and the engine quits. So I always get to a position to make the field prior to turning off the electric pump after takeoff. That was also my logic for not using it during practice approaches, since at 120kts (which is what I've been using as an IFR approach speed before decelerating once I break out. I would have time to turn the pump on while I climbed bleeding off energy to best glide.
Good point though. I think for IFR approaches the pump should come on at the FAF, VFR ops, initial or entering the downwind.
Evan Levesque
RV-8 N88MJ (Built by Michael Robbins)
Lemoore, CA
Old 04-07-2020, 05:45 PM
Drum Drum is offline
Default Wrench on it
Nice write-up/de-brief. This is the second similar issue Iíve heard of in as many months. Other was a loose fluid fitting on a Grumman oil cooler which backed off during a test flight after engine replacement. A quarter turn later and most of the oil found itself on the belly of the a/c. I echo the comments of another gentleman here who suggested not to be shy about putting a wrench on every bolt and fitting firewall forward. Thanks for sharing.
Drum G
RV-8
Fitting Wings
Old 04-07-2020, 08:47 PM
rmarshall234 rmarshall234 is offline
My buddy Jeremiah Jackson crashed his new RV-10 on the 4th flight due to an oil line that wasn't torqued properly and subsequently dumped all the oil overboard. Occurred ~ 8 miles east of Ramona inbound after a 2 hour Phase I flight. He wrote a good book about the experience called "4 Minutes". Also gives a really good talk about it in the San Diego area if you ever get a chance to catch it. He's a good speaker.
Old 04-08-2020, 09:50 AM
XPPilot XPPilot is offline
Default Sum of luck vs. Superman
Great write up and statement below is so true!
THE TAKEAWAYS
This thing we call luck is merely professionalism and attention to detail, it’s your awareness of everything that is going on around you, it’s how well you know and understand your airplane and your own limitations. We make our own luck. Each of us. None of us is Superman. Luck is the sum total of your abilities as an aviator. If you think your luck is running low, you’d better get busy and make some more. Work harder. Pay more attention. Study your [POH] more. Do better preflights.
- Stephen Coonts "The Intruders"
Old 04-08-2020, 10:13 AM
sblack sblack is offline
I always think of the Alaska Airlines crew that stripped the threads on the hstab jack screw. The stab jammed so they did some trouble shooting in the air and in the process stripped the threads completely and the tail came off and the airplane went straight in. Had they just declared an emergency and landed with higher but manageable workload they would have been fine. Any troubleshooting other than the most basic stuff us best done on the ground. There is almost nothing so bad that you canít make it worse. Thank you for sharing.
Scott Black
Old school simple VFR RV 4, O-320, wood prop, MGL iEfis Lite
VAF dues 2020
Instagram @sblack2154
