Old 03-18-2020, 05:46 PM
Toobuilder's Avatar
Question Need Crank - Reman or New?
My 540 suffered a significant overspeed last summer and it's just now working through the shop. Long story short, the overspeed event cracked one of the counterweight ears. Shop is giving me the option of an overhauled or new crankshaft - the latter at a substantial price premium.
The price difference is not a major problem, but certainly worthy of consideration. The main issue I'm now struggling with is whether the extra cash actually buys me any benefit. It seems obvious to go with new, but I've been bitten by the "improperly manufactured" crank AD once before, and there's a NEW one out currently. OTOH, a properly overhauled and inspected used crank has lived through the gamut of AD's and is likely to simply keep on truckin' until fatigue or wear finally takes it out of service.
Has anyone faced a similar choice or have any opinions that favors one or the other?
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 03-18-2020, 06:17 PM
With the various shut-downs I've been hearing about, perhaps the one most quickly-obtained would be the way to go.
I wouldn't hesitate with the reman, assuming it was done correctly by a reputable shop. Caveat, I'm not an engine guy, just an old stress engineer.
Only thing I can think of is a potential issue at TBO. If the overhauled crank has been turned down a few times already, it may be at its limits -can't be turned down again. Can you find out the current dimensions of the used crank bearings?
Old 03-18-2020, 06:51 PM
Toobuilder's Avatar
Any crank that goes back in the engine will be within "new" standard tolerance - just like the "AD" crank that came out, and the reman that went in 3.7 hours ago to replace it (now cracked).
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 03-18-2020, 09:23 PM
RV7 To Go RV7 To Go is offline
Certainly no expert here but I wouldn't have an issue either way. Running an overhauled crank in my 360. So far 370 hrs with no issues. The club uses reman cranks in their rebuilds and they go over 3000 hrs consistently. As long as it is done by a reputable shop should not be an issue. Haven't really heard about engines failing due to broken cranks unless they have been abused or have a manufacturing defect...ie. overspeed or prop strike with no bulk inspection after or an AD issue....
Used both new and overhauled in my hot rod days. Never had a crank fail...threw a couple rods though.... FWIW.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
Old 03-18-2020, 10:38 PM
Flybipe Flybipe is offline
Default I went new...
My builder went with a new one, and I asked him to have it cryo-treated.
https://www.kitplanes.com/coming-into-the-cold/
Old 03-19-2020, 07:04 AM
lr172 lr172 is offline
This is my current thinking. No current evidence to suggest age has any impact on potential crank failure, assuming positive NDT results. On the flip side, it seems many cranks produced in the last 10 years are suffering from failures due to manufacturing issues.
Seems there is little to no evidence to support the logic that new is better and some evidence to imply old, used is better. Your stated experience would seem to back that up.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 03-19-2020, 10:01 AM
skylor's Avatar
skylor skylor is offline
Default Lycoming
[quote=lr172;1415741]
/QUOTE]
I don't think factory Lycoming cranks manufactured since about July, 2005 have any known issues, service bulletins or AD's against them. The current issues seem to be with aftermarket crankshafts.
Skylor
Old 03-19-2020, 10:31 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I think it was early 2006 when the last crank SB was issued from Lycoming so you should be safe getting one that was made after that.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 439.3 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 03-19-2020, 10:36 AM
Jpm757 Jpm757 is offline
Unfortunately Lycoming SB 505B (corrosion inside hub) has taken a lot of otherwise good cranks out of service (one of mine included). The price of O/H crankshaft remains at a premium. Sold mine to the airboat guys for $500.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 300+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
