Old 03-16-2020, 01:01 PM
JHartline JHartline is offline
Default Quick drain oil plug
For those that have put a quick drain on an IO-390... Love it, hate it? Which one did you use?
I got 92 hours on my plane and itís about time for condition inspection #1. Plus I havenít spent any money at ACS in at least 2 months. Iím overdue.
James Hartline
Carrollton, GA 5GA2
RV-14 - First flight 4/7/2019. Phase I complete as of 9/11/2019!!
Old 03-16-2020, 01:43 PM
bkervaski's Avatar
bkervaski bkervaski is online now
Love it. Really worth it, makes oil changes a breeze.
Be sure to put it on front left port on the IO-390 (don't try to install it on the back). Assuming you're FF is by the book, it will clear everything there.
I got this one, nice quality and installs in about a minute:
https://shop.vansaircraft.com/cgi-bi...duct=oil-drain
Note that if you don't let the oil drain completely out and close the valve you'll get a false impression it's leaking. In these cases, I used a q-tip to get any excess out of the tip after closing, but it's not an issue if you give it plenty of time to drain empty.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 03-16-2020, 02:21 PM
Scott Hersha Scott Hersha is offline
Very much a worthwhile thing to have. I have a feeling that this $10 part is $81 because the liability insurance is astronomical, and they donít sell that many of them, and it will last you forever. You may have to replace an O-ring far into the future, but thatís only a nickel.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 03-16-2020, 03:07 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Fumoto
Here's another option: http://www.vansairforce.com/communit...d.php?t=177598
I have one but have not yet installed it. I will do it on the next change I guess.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 03-16-2020, 05:48 PM
JDA_BTR JDA_BTR is offline
I like mine - left front....
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 03-16-2020, 06:20 PM
fl-mike's Avatar
fl-mike fl-mike is online now
Support Saf-air if you can. They stand behind their products. I mentioned that mine came with a small nick that I had to dress to stem a minuscule drip (while visiting their booth at OSH). The owner (canít recall his name) handed me a new one. Instant customer for life.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS, L3 Lynx NGT-9000
N164WM
N184WM reserved (RV-8)....finishing kit in progress. Titan IOX-370
Old 03-16-2020, 07:14 PM
Default Options...
I should have specified which type plug, not which drain hole. My bad. Also, for the conventional gear -14 the front left drain is really the only choice for normal oil changes.
The one Vans sells looks just like the Saf-Air sold by another common seller and itís $10 less. The Fumoto T202N can be found for around $35 but it doesnít have the cool-looking anodized coating. More shopping to do I guess...
James Hartline
Carrollton, GA 5GA2
Old 03-17-2020, 07:12 AM
Nova RV Nova RV is online now
I have the Saf-Air and it works great, put a length of hose over it when you drain and the mess goes right into your container.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP, B-1900, A319/320, B-757/767, B-737, Flight Engineer-Turbojet
RV-14A kit # 140243 (flying as of 11/18)
VAF 2018 and 2019 paid
www.mykitlog.com/chrismoon/
Old 03-17-2020, 07:52 AM
sailvi767 sailvi767 is offline
The quick drain on the Rocket is on the left front. Do most of you lift the tail during a oil change or does sump design make that unnecessary?
G
Old 03-17-2020, 09:21 AM
Thanks all. Yes, left front and I lift the tail to get as much out as possible. This time Iíll be able to use my tail lift and save my back
James Hartline
Carrollton, GA 5GA2
