Old 03-16-2020, 11:07 AM
rolick22's Avatar
rolick22 rolick22 is offline
Default N112DR First Flight
The first flight of N112DR on March 14, 2020.
The aircraft was slightly right wing heavy and the AHRS was not keeping a level attitude, also I need to adjust the AST trim indication. Anyone know if the stall horn is supposed to stay on for 5 second after recovering from a stall?
Please see first flight video here https://youtu.be/cdGVcMkeDjw
To see the chase plane video flown by Dave G, please visit the RV12 Pilot YouTube channel. The Test pilot was Dave H.
https://youtu.be/95g3gSxR9eY
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
N112DR
VAF donation made for 2020
Old 03-16-2020, 11:30 AM
Default Congratulations
David, congrats on the new fledgling
Old 03-17-2020, 12:53 AM
StrictlyEXperimental StrictlyEXperimental is offline
Smile Very, Very Nice Dave
Stayed up way too late but it was worth it. Will I make progress on my wings tomorrow? You Bet! I'll be thinking about your bird.
John S.
Old 03-17-2020, 02:02 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
Congratulations!
About the stall warning; it's not normal. The moment I unload the stall warning stops. Your artificial is also doing "funny" things especially during recovery
PH-BZT
MyKitlog
Old 03-17-2020, 06:51 AM
rolick22's Avatar
Originally Posted by Gagarin737 View Post
Congratulations!
Ya not sure if it's getting stuck or its a software function. Looking into, As far a the artificial goes I'm leaning towards maybe the Magnetometer not being calibrated correctly. But I really don't know.
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Need:
Paint?
Serial#12-0864
N112DR
Old 03-17-2020, 08:42 AM
Did you do the rosette procedure, in setup mode, to orient the device to magnetic north, before flying? you point the plane N, E, S, W with the GPS 2020 unit on, watching the satellite readings to get a good signal, to reorient the magnetic portion.
See instructions, for GPS 2020 antenna. Maybe that helps.
BTW, either weirdest looking optional tail dragger wheel ever, or a Go Pro located unusually far aft. ;-)
Old 03-17-2020, 11:59 AM
rolick22's Avatar
Yes did everything per the G3X/G3X Touch Installation Manual, and yes that's a GoPro tail wheel.
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Need:
Paint?
Serial#12-0864
N112DR
Old 03-17-2020, 11:30 PM
Never been a Dad, but first flight seems to be the closest I will be ever be to watching my new born. Congrats, itís quite an accomplishment only a relative few can boast about!👍
Old 03-21-2020, 12:42 PM
rolick22's Avatar
Default New Air to Air Version
https://youtu.be/biOoW5AbhZw
Integrating the two planes Air to Air.
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Need:
Paint?
Serial#12-0864
N112DR
Old 03-21-2020, 01:00 PM
Azjulian Azjulian is online now
On your horizon issue, I would rerun in the configuration screens
1. The pitch / roll offset procedure
2. Also do the engine run up vibration test
Did you use the correct bracket for the magnetometer (compass) in the tail ?
The ADAHRS is located in the pilot side back of the baggage area (at least it is on mine unless a recent plane changed moved it). Have you confirmed that is firmly screwed down into its mounting plate and the mounting plate is secured securely in the baggage area ? I would verify all of this and then do the two things I mentioned above and after all that repeat the compass rose procedure.
