Old 03-15-2020, 12:16 PM
airguy's Avatar
airguy airguy is online now
Default Vans ES Dimmer pinout?
Does anyone have the diagram handy for the ES Dimmer module for LED strips that Van sells? Specifically I am looking for the wiring to the four terminals.
Greg Niehues - SEL, IFR, Repairman Cert.
Garden City, TX VAF 2020 dues paid
N16GN flying 650 hrs and counting! IO360, SDS, WWRV200, Dynon glass, 430W
Built an off-plan RV9A with too much fuel and too much HP. Should drop dead any minute now.
Old 03-15-2020, 12:31 PM
rvbuilder2002's Avatar
I think it is printed on the pcb.
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 03-15-2020, 06:52 PM
airguy's Avatar
Not on the one I have, unfortunately - circa 2014
Old 03-16-2020, 10:35 AM
Ralph Inkster Ralph Inkster is offline
Vans ES DIMMER 1.5A instruction page "TE810-1 Cockpit Lamp Dimmer"
With the circuit board facing you, heat sink on top. The 4 connections from left to right:
1- potentiometer control (either wire) and optional ground
2- potentiometer control (either wire)
3- output voltage to lamps
4- input voltage - they show to nav circuit breaker / switch
I don't think this dimmer is specifically for LED unless you gang up the lamps to knock down to the required voltage. The instruction sheet shows voltage output range from 1.2v to 9.5v (12 input voltage less 2.5v)
PM me with your email if you want me to scan this sheet.
Ralph
It's time to work on just my own planes, not everybody else's...
