Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Electrical Systems
Old 03-11-2020, 08:13 PM
scottjohnsontampa scottjohnsontampa is offline
Default Alternator to fit on Lycoming 0-360 vacuum pump drive drive
I am replacing my vacuum AI & DG with Garmin g5's so I can rip out my vacuum system. There are two alternators by B&C that fit the vacuum pump drive. They are 1.) B&C BC410-H SD ALTERNATOR 20-30 AMP
2.) B&C BC462-H ALTERNATOR 35-45 amps. Does anyone know if the larger alternator that produces 35-45 amps will fit on a lycoming 0-360 vacuum pump drive mounted on an RV-6A? Also, are there any other options for a vacuum pump drive alternator I should consider? I do have a primary alternator from Vans, but desire to have a second one after I have pulled out the vacuum system.
Old 03-11-2020, 08:24 PM
Mike S Mike S is online now
I have used a B and C 8 amp with second battery in the past, and am doing the same in my current build.
Old 03-11-2020, 09:33 PM
RV7 To Go RV7 To Go is offline
I used the B&C 20 Amp on the vac pad on my 7. The electrical is set up as per the Aeroelectric plan with an E-Buss. In the event of a main alt failure the BU can be turned on and run minimum electrics, if required, on the E-Buss. In my situation with 1 EFIS & radio, LED lighting, transponder & 496 BU GPS the BU will run it all with no problem without switching to the E-Buss.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
Old 03-11-2020, 11:10 PM
Default Question from Osh
I asked this question of B&C at Oshkosh 2019. They said the smaller one fits no problem. The larger one will fit, but it seems to cover the mechanical tach drive on the 0320/360 Lycomings. But for a Garmin panel, from what i understand, the mech tach drive is not used, rather the G3X gets the tach signal from the mag.
There is a post a few years ago about this ( using the vac paid as the prime alternator).
One thing to note is I think the vac drive RPM ratio is 1.3:1, so the alt rpm is lower than a standard belt drive alt. This will be OK for my all-Garmin system with LED lights, but for others the alt may not put out enough juice.
This is my plan for my 9A. I have no knowledge about anything RV-6, so i am only speaking for the Lycoming compatibility. YMMV. JMHO.
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 10% Canopy
Electrical 5%
Engine In Stock
Old 03-12-2020, 06:25 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Answers on B&C for 360
FWIW the little SD8 on my RV3 does a great job. How much backup juice do you really need.
The 462 WILL clear the oil filter ( Lycoming/Superior adapter) and the tach drive casting. B&C has been advised with pics that filter clearance is about 1/16 inch.
As noted above, the 1.3 drive ratio inly puts out 30 amps at say 2400 cruise RPM.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 03-12-2020, 07:16 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
The B&C 20 amp alternator is a superior product, and when used with the B&C standby voltage regulator, normal installation has it running in parallel with your primary alternator. The standby alternator output is zero if the primary alternator is operating. In other words, if your primary alternator fails the 20 amp standby alternator automatically picks up the load - no pilot action. You will know this happened by two indications:
- Bus voltage will go from your normal (~14.1vdc) to the whatever you set the standby alternator at (~13.5vdc).
- The nice little yellow LED provided with the standby voltage regulator will come on.
This is about as simple as it gets.
