Old 03-11-2020, 01:56 PM
rapid_ascent rapid_ascent is offline
Default BC410 Standby Alternator w/ Titan IO-370
Has anyone used a BC410 standby alternator with an IO-370? It appears that the longer oil filter adapter may interfere with the alternator. I'm curious if anyone has worked through this issue?
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 03-12-2020, 07:20 AM
Well... No comments.
How about if I make the question more generic. Does anyone have any experience with the interference between the standby alternator and their oil filter adapter?
After talking to B&C it seems the only solution is to use a shorter spacer.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 03-12-2020, 07:26 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Alternator response
Cant speak specifically about ECI 370. The B&C 462 ( assume 410) will clear the Lycoming /Superior oil filter adaptor that comes straight out the rear of the acc. Case.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 03-12-2020, 07:33 AM
The adapter that came on the engine is a right angle adapter.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 03-12-2020, 07:50 AM
Mark Dickens's Avatar
Yep, this is my setup. It requires the 90 degree oil filter adapter
http://www.marksrv8.com/img_0613/
Edit: And I do remember having to get a shorter extension for the oil filter.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 03-12-2020, 08:40 AM
Walt's Avatar
Walt Walt is offline
Had Titan swap the angle adapter for a straight (superior) adapter on my new 370, BC410 installed with no issues. I'm pretty sure the BC410 won't work with the angle adapter supplied.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-12-2020, 09:37 AM
Walt, i’m starting to think that is what I’m going to have to do too.
Mark, do you know the spacer length? There seems to be 3 standard lengths. I think it’s .75”, 1.4” and 2.5”. I pretty sure as shipped mine has the 2.5” spacer. That’s a no go according to B&C. The 1.4” requires an extender kit which I would prefer not to do.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 03-12-2020, 11:26 AM
I may be going out to the airport this afternoon and will check.
www.marksrv8.com
Old 03-12-2020, 11:55 AM
Anybody used a remote oil filter in this setup?
Old 03-14-2020, 05:16 PM
I finally got out to the airport today and took the below photo:
The 3/4" extension positioned the oil filter mount exactly where I needed it to be.
www.marksrv8.com
