Old 03-09-2020, 01:32 PM
Mongoose Mongoose is offline
Default Starter didnít disengage
When I started my RV-14A today I had a grinding noise and my amps were showing about 34. Once I got the cowling off I discovered the starter gear was still engaged. I got it clear and then when I would turn on the master it would engage again, it didnít crank the engine however. I tapped the starter solenoid and now is all good. I assume a bad solenoid but wanted to get other opinions.
Thanks.
Old 03-09-2020, 01:37 PM
New setup, or been flying for awhile?
What starter?
Old 03-09-2020, 01:49 PM
About 25 hours on the plane. It has a sky tech starter. Wired per Vanís plans.
Old 03-09-2020, 01:52 PM
Ralph Inkster Ralph Inkster is offline
Starter Switch malfunction?
Ralph
It's time to work on just my own planes, not everybody else's...
Old 03-09-2020, 04:50 PM
jpowell13 jpowell13 is offline
Had a Toyota Corona with an ignition switch that stuck. Destroyed the starter. John
Old 03-09-2020, 06:38 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Give Skytec a call, I had a good experience with their customer support.
Rob Lasater
Rv-14 still workin, but getting close
Paid Dec 2019
Old 03-09-2020, 11:20 PM
lr172 lr172 is offline
I had this on my new 10. The starter button had a burr on it and would stick in the engaged position. That said, your comment about clearing it with a hammer on the solenoid would point to a bad solenoid. They can also hang up due to mfg defects.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 03-09-2020, 11:25 PM
Bavafa Bavafa is offline
Plus one, as it looks like the solenoid was stuck. You are not the first one but probably not so early in the hours of use.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 03-10-2020, 05:08 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
My starter solenoid stuck on too.....after 900 hours.
My repair included a panel light indicating the starter was engaged.
There is a lot going on up front when this happens and a few tell tale signs on the panel let alone the strange sounds....so I now a light that confirms the issue quickly......although it may never happen again.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 03-10-2020, 11:42 AM
Thanks.
I'd still have a look at the starter switch.
Ralph
