View Poll Results: What did you do with the stall warning pilot holes?
Plugged with rivets 12 44.44%
Left open 0 0%
Installed the stall warning switch 14 51.85%
Something else 1 3.70%
Voters: 27. You may not vote on this poll
Old 03-01-2020, 07:41 PM
iamtheari iamtheari is offline
Default Stall Warning Switch Pilot Holes
Iím trying to decide what to do with these two holes. Leave them open, dimple them and put in AN426AD3-3 rivets to plug them, or something else...what did you do?
Old 03-01-2020, 07:48 PM
Carl Froehlich's Avatar
A little mico in the holes, then before it sets a single bid of fiberglass (small) on the inside as a backer for the micro. Let set and sand flush.
Old 03-01-2020, 10:11 PM
Default Me
I installed the stall warning. But i wish i had just plug them. I might still. I found that stall warning vanes catch rags when cleaning the wings.
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 10% Canopy
Electrical 5%
Engine In Stock
Old 03-02-2020, 05:08 AM
mturnerb mturnerb is offline
I also installed the stall warning vane. It was nice to have before I calibrated AOA and also I like the redundancy. Definitely a bit of overkill, but I'm comfortable with it.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
Old 03-02-2020, 05:21 AM
RViator60 RViator60 is offline
I installed the stall warning switch and the AoA for the added redundancy. Have the stall warning vane in my 73 Cherokee 180 and never had an issue.
Marty Guinn
Based at KSUT, Southport, NC
- 1973 PA28-180 (N55087)
RV14A Build
- Started Sep19, Aft Fuse complete
- Wing assembly underway,
- IO390 ordered (Oct20 deliv)
- Hartzell 2-blade composite on order.
https://eaabuilderslog.org/?s=MartysRV14A
Old 03-02-2020, 07:36 AM
kbalch's Avatar
kbalch kbalch is offline
I dimpled those holes and filled with flush rivets.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - Flying!
RV-14A.com
N114KB Build Site
RV-14(A) Fuel Tanks
RV Builder Assistance
RV First Flights
Old 03-02-2020, 08:34 AM
Bavafa Bavafa is offline
Very similar to Carl, covered/plugged it but not with rivets.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 03-02-2020, 09:22 AM
JDA_BTR JDA_BTR is offline
Installed the warning tab. I have aoa but like hearing the tone on an aced landing.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 03-02-2020, 01:27 PM
The few times I've aced a landing, I wasn't able to hear anything over the sound of patting myself on the back.
Old 03-02-2020, 01:37 PM
bkervaski's Avatar
I want to remove my stall warning switch. All the tab does is snag everything and everybody that gets near it.
The AoA does really well.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
