Old 02-25-2020, 09:05 PM
ethand ethand is offline
Default Cooling Tips for Cylinder #6
My #6 CHT is a good 10 -15 degrees higher than any of the other 5 cylinders. The EGT is in line with the others.
Thoughts on opportunities to assist with airflow?
I improved the sealing on the oil door and made some improvements to the baffles and that helped a bit but looking for more. I also looked in the area and sealed a bit more on the inboard rear with RTV to force the air over the cylinder.
My oil temp is running about 180 so I may try to block a bit of the flow to the cooler and see if that helps.
Other thoughts?
E
RV-10 N77319
2192 Days of Building
Completed May 2019
Phase 1 completed Nov 2019
62 hours and counting.....
Old 02-25-2020, 09:24 PM
Robin8er Robin8er is offline
10-15 degrees isn't bad at all. But I had the same issue with the cylinder by the oil cooler. I blocked off part of the pilot cooler and it brought the temp on that cylinder down about 15 degrees. It also helped bring my oil temp up. My oil temp was running around 175-180.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 02-25-2020, 09:39 PM
BobTurner BobTurner is online now
Forget the absolute egt number. How far is the egt from peak egt (assuming rich of peak), and what is that value for the other cylinders? E.g., is #6 running 50 F rich of peak while all other cylinders are 100 F rich of peak?
Old 02-26-2020, 07:50 AM
lr172 lr172 is online now
where is the #2 CHT? If it is on the low end of your range, you can try increasing the height of the #2 air dam. That should increase #2 and lower #4 and #6.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 02-26-2020, 05:59 PM
paul330 paul330 is offline
http://www.vansairforce.com/communit...d.php?t=143064
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 02-27-2020, 08:14 AM
douglassmt douglassmt is offline
He said CHT, not EGT
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
Old 02-27-2020, 08:16 AM
Other thoughts?
E
If you have a stock build you're losing some cooling air on #6 to the oil cooler. Seal it all up the best you can, maybe get a butterfly valve for the oil cooler, and you'll be fine. 10-15 deg higher is nothing unless you are over 380-400.
Bryan Douglass
RV-10 N242BD
Old 02-27-2020, 10:08 AM
He said ‘the egt is in line with the others’. My comment was that you want to know how far from peak egt you are, on each cylinder. Having absolute egt readings is not the same. If #6 is running 50F rich of peak and all the others are 100 rich, you’d expect #6 cht to be higher.
Old 02-27-2020, 11:07 AM
It was my understanding that peak CHT is at max power mixture (80-100 ROP) and will slowly fall as you go leaner, to around peak EGT and then drop more rapidly as you go leaner still. Similarly, CHT will also fall from it's peak if you go richer from max power. This assumes, of course, that ambient and ignition timing remain the same.
so, if #6 is 100 ROP and all others were at peak, I would expect #6 CHT to be a bit higher. The Lyc charts show a relatively small change in CHT between 250 ROP and peak.
