Old 02-10-2020, 06:27 PM
Deuelly Deuelly is offline
Default New engine from Vashon/Dynon founder
What do you guys think of the new engine that John Torode has going at EPI?
Any RV potential? Maybe RV-12 or super efficient RV-9?
http://www.epi-eng.com/aircraft_engi...aft_engine.htm
Brandon
Old 02-10-2020, 07:38 PM
PhatRV PhatRV is offline
I like the idea of a turbo charged version they had planned for this engine.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- On Gear
Avionics Installation -- started
Donation paid through 2020
Old 02-11-2020, 08:59 AM
rongawer rongawer is offline
It looks interesting. I'm always hopeful that someone comes along with a better mouse trap. However, it looks a lot like a UL Power UL350iS, which is 123 hp at 2800 rpm continuous (130hp at 3000 5 minute limit) and 160 pounds, plus 13 pounds of airframe mounted accessories and already has EFII with FADEC.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 02-11-2020, 09:29 AM
airguy's Avatar
airguy airguy is offline
Both of which are preferable to the current 100hp offering, with modern features. So that would put two vendors competing for that market - which is exactly where we are today (Lycoming/Continental) but with a better engine. If that's the case, I'll take it - it's still good forward progress. Couple more of those and you'll have a first down.
Greg Niehues - SEL, IFR, Repairman Cert.
Garden City, TX VAF 2020 dues paid
N16GN flying 650 hrs and counting! IO360, SDS, WWRV200, Dynon glass, 430W
Built an off-plan RV9A with too much fuel and too much HP. Should drop dead any minute now.
Old 02-12-2020, 09:35 AM
With all due respect, have you priced a UL Power engine in "ready to fly" condition? In the case of this new engine, the price point will, if they hit their targets, be a strong motivating force in the market.
The last time I priced a new O-200 it was north of USD$24K. If this engine comes in even at USD$16K it will have a significant advantage.
Old 02-12-2020, 11:23 AM
If the pricing target is true, it will be a great powerplant option for the SLSAs that now use the Rotax engine. The price of the Rotax is approaching the higher cu inch traditional 100LL aircraft engines.
Wing -- Closed
Fuselage -- On Gear
Old 02-12-2020, 01:23 PM
rvbuilder2002's Avatar
Maybe...... will depend on the airplane it is intended for.
Their final goal weight is still a bit higher (15-20 lbs) than the fully installed weight of a Rotax 912. Not huge, but a factor that would have to be considered in many airplanes. And that is assuming that the claimed weight is with an exhaust and other required accessories. If it is not (pretty common), then the weight delta would be even wider.
Even then I think could be a game changer if they are eventually able to deliver an engine at about $12K
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 02-12-2020, 03:02 PM
Brdog42 Brdog42 is offline
Default $14-15,000
https://www.youtube.com/watch?v=6-HR...ature=youtu.be
In the comments, a target price of $14-15,000 was mentioned one month ago.
Tim
1973 A150L sold
RV-6A restoration in progress
KCHD AZ
__|__
*>O-(_)-O<*
Old 02-12-2020, 03:19 PM
The cost quote I remembered from the video was "less than half the current cost of a Cont. O-200, which I think is currently around $24K (the reason I wrote 12K)
Scott McDaniels
Hubbard, Oregon
Old 02-12-2020, 03:34 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Lot's of good info in general
I never took a close look at the EPI website before yesterday. In addition to the engine that the OP referenced, there is a ton of good information on internal combustion engine design and theory.
I don't want to start a politcal discussion on this forum, but there is a very interesting write-up on energy technology under the "What's new" tab. Check out the topic "contemporay energy mythology".
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
