Old 01-25-2020, 10:00 AM
backcountry backcountry is offline
Default Tool to break the canopy
It is possible that a RV-12 could get into an upside down position as may take place in conducting a forced landing.
This would result in not being able get out of the aircraft because of not being able to open the canopy.
With this mind I would like know some recommendations on canopy breakers that could be used to get out of the aircraft. I think this should be standard equipment.
Old 01-25-2020, 10:19 AM
jrtens's Avatar
jrtens jrtens is offline
I carry a small hatchet behind the seat.
https://www.lowes.com/pd/Estwing-E24...E&gclsrc=aw.ds
Jon
RV-12iS
Salt Lake Int'l
Old 01-25-2020, 10:28 AM
Northernliving Northernliving is offline
There are a few threads on this topic if you do a search. Here are a couple.
http://www.vansairforce.com/communit...rchid=42606494
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 01-25-2020, 11:41 AM
DHeal DHeal is online now
FWIW, I carry a pair of leather work gloves and a multi-tool (with sharp point, saw, and pliers) in my RV-12's glove box. I figure that I can more effectively deal with recalcitrant plexiglass shards if wearing gloves.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 910+ hours (as of May 2020)!
VAF donation through June 2020.
Old 01-25-2020, 12:32 PM
Wolfgang Wolfgang is offline
I bought a cheap small hammer and ground the head to a point and mounted it on the arm rest on the passenger side ...it is held in place by a clip you buy at any hardware store that is made to hold, say, a broom handle on the wall.
Old 01-25-2020, 12:37 PM
snopercod's Avatar
One of these would work, I think: 12-Volt MAX CXT Lithium-Ion 3-3/8 in. Cordless Circular Saw
(2020 dues paid)
Old 01-25-2020, 03:21 PM
Carlos151's Avatar
Carlos151 Carlos151 is offline
Originally Posted by snopercod View Post
Too funny . Itíll definitely work and you can also use it for your weekend wood projects.
Flyboy Accessories has a nice chisel tool. Got one in my -8
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
TN26
Old 01-25-2020, 03:51 PM
JDeanda JDeanda is offline
Default Canopy Buster Tool
Some friends and I did some tests on an RV-9A that was being parted out. We strapped two pilots into the cockpit of the airplane with the wings off and rolled it inverted. We tried different tools to break the plex. Short version... the hatchet was BY FAR the best tool for breaking the canopy. The aluminum wedge-shaped tool was the worst. BTW, we also learned itís best to break the canopy BEFORE releasing the harness. You can get a much better swing while seated inverted than if youíre sitting on the inverted canopy.
Old 01-25-2020, 04:20 PM
N804RV's Avatar
N804RV N804RV is online now
I got one of these. Its lighter than the hatchet, and just slightly larger than some of the so-called "escape-tools" that are for sale. I figure its pretty easy to **** it (net nanny is so funny!) , even when you're upside down, hanging from the straps. One or to punches to get a good crack started, then its solid enough to use to bash your way out. ---------I've been told by a couple of folks that this is overkill. But, .....till proven otherwise, it makes me feel better.
penetrating bolt gun https://www.bunnyrancher.com/store/p...Bolt_Gun_.html
Ken W.
Mount Vernon, WA
2019 VAF Supporter
Old 01-25-2020, 05:47 PM
tomkk's Avatar
tomkk tomkk is offline
https://www.youtube.com/watch?v=fRvQxGl4kt4
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
