Old 10-10-2019, 12:57 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default MANDATORY ROTAX® Alert SB
Replacement of fuel pump assy. for ROTAX® Aircraft Engine Type 915 i A and 912 i (Series)
https://legacy.rotaxowner.com/si_tb_...b-912i-011.pdf
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 10-10-2019, 01:01 PM
I wonder how many Bing carb floats you can buy for the cost of replacing this pump?
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 542
LSRM-A Certificate 2016 for RV-12 N633CM
Old 10-10-2019, 02:15 PM
RV12JT RV12JT is offline
I was on the fence ordering my Sling 2, as to which engine I wanted. TAF convinced me that maybe I’d want the 912 ULS, at the time, rather than the iS. All due to the VIRB ration issues the iS was still exhibiting. So far, I’ve only had one recent SB, for carb circlip replacement, less than an hour job. On the other hand, the iS motors have had several SB,s, especially the 915i#.
Old 10-10-2019, 04:08 PM
jcl777 jcl777 is offline
Default Engine Serial Number
At least based on the engine serial numbers affected, I'm in the clear. My mechanic will check the part serial numbers anyway. Anything labelled "before next flight" gets my attention real quick.
John Leon
Kingwood, TX
RV12-iS, N221TF, #121130, non-builder
Old 10-10-2019, 04:50 PM
jrtens's Avatar
jrtens jrtens is offline
You may want to take another look. I don't see any engine serial numbers listed.
Jon
RV-12iS
Salt Lake Int'l
Old 10-10-2019, 06:15 PM
You're right...was looking at something else.
John Leon
Kingwood, TX
Old 10-10-2019, 06:26 PM
Bob Y Bob Y is offline
Just as a point of reference, I received my Powerplant kit May 20 this year. My pump assembly SN is 18.0708, which is within the potentially impacted range.
Bob Y - builder 12iS
N569TT first flight 2/9/2020
Old 10-10-2019, 06:44 PM
engineerofsorts's Avatar
engineerofsorts engineerofsorts is offline
Default Fuel pump serial number availability
One problem I see in checking the serial numbe for the fuel pump assembly it’s that, per the KAI, the first thing to do is remove the cover on the fuel pump assembly, and not put it back on. We most likely disposed of this in-needed cover, so, unless we have the serial number on our documentation, we may be up that well-known polluted tributary without a means of propulsion. It appears the two actual fuel pumps do have serial number, which we could read—but we need to know what fuel pum ranges have the bad innards.
Rob Reese
RV-12 #120332 N73HR
Austin, TX
TangoFlight Mentor
Old 10-10-2019, 07:01 PM
The SB indicates the potentially impacted S/N ranges: 180500-192699.
Old 10-10-2019, 07:47 PM
Default Well, yah, but
This is the ASSEMBLY part number range. This is on the cover of the assembly, which cover was removed for the RV12iS implementation. There are serial numbers on each of the two FUEL PUMPS, which we should still be able to read—but the service bulletin says nothing about the serial number range of the bad individual fuel pumps.
Rob Reese
RV-12 #120332 N73HR
Austin, TX
TangoFlight Mentor
