Old 01-21-2016, 05:31 PM
Default Canopy Latch Question...
I have seen a picture of a RV-12 canopy latch handle where the strike plate ends up between the loops of the handle. On my 12 (SN 120058) the handle has a tab on one end and this is what engages with the strike plate. I’m wondering if there was a design change somewhere along the way. Sorry for lengthy (poor) description. I wish VAF allowed easy file attachments so I could just show a pic. Thanks in advance...
I believe the photo below is the new design with striker plate between loops of the handle.
https://drive.google.com/open?id=0B9...VQ5VzBCUGFVR2M
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 537
LSRM-A Certificate 2016 for RV-12 N633CM
Old 01-22-2016, 05:43 AM
Added photo to original post above...
EAA #499867
Old 01-22-2016, 06:12 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
sent request for permission to access the image
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
Old 01-22-2016, 06:40 AM
Sorry guys. Google Drive isn't letting me change sharing permissions. Bad computer day...
EAA #499867
Old 01-22-2016, 07:14 AM
PilotBrent PilotBrent is offline
Default Suggestion
Suggest you use TinyPic.com and post the image on VAF directly
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 01-22-2016, 11:15 AM
Ex Bonanza Bucko Ex Bonanza Bucko is offline
I have an SLSA RV12 bought from Van's. I didn't notice how the handle was used in the latch.....tab or inside the handle loop...I only knew it was closed and the green light was on. Then the light went out in flight...canopy didn't come open. I messed around with it on the ground and now I see that the latch will only be secure when the closure is inside the loop....at least on my bird.
It takes a little muscle to get it closed however.
EBB
Old 01-22-2016, 12:09 PM
Here from TinyPic...
Thanks I learned something new today with TinyPic. Anyway, as you can see in the pic... the strike plate is within the handle loop. On my plane the extension tab only engages the strike plate. The extension tab is at the end of the handle loop. I will use drawings mentioned by Mitch757 for Default Canopy Latch - Check Vans Notification 14-05-22. I'll try to sort this out as soon as weather permits. Thanks for all the help. VAF is great...
EAA #499867
Old 01-22-2016, 01:10 PM
engineerofsorts's Avatar
engineerofsorts engineerofsorts is offline
Default What is the issue?
From the looks of it, this is how its supposed to work. With the strike plate inside the hoop, closing the canopy up does pull the canopy and the roll bar together nice and snug. If it were on the outside of the hoop, it would be pushing them apart. I can't tell for sure, but it appears you used the standard LP-3/4 rivets to attach the UHMW strike plate (on the hook)--I believe it should be countersunk such that the hoop, when running over that UHMW plate, doesn't have to go over and LP-4-type rivet heads.
Thinking a bit more about it--the two rivets shown are just fine as LP rivets--I believe there is a third rivet which is countersunk hidden where the loop makes contact with it.
Rob Reese
RV-12 #120332 N73HR
Austin, TX
TangoFlight Mentor
Old 01-22-2016, 01:44 PM
Just to clarify...The pic above is not my plane. Mine has the striker plate on the outside of the handle loop. I don't have a picture of my latch. Something's not right with my setup. It works fine and it appears safe but apparently something is amiss. I'll report back when weather permits and also provide photo.
EAA #499867
Old 01-22-2016, 02:10 PM
DonFromTX's Avatar
From what I have read, it would appear that someone building yours drilled the hole in the canopy in the wrong place!
Retired US Army Officer
