Old 03-07-2020, 07:19 PM
Jake14 Jake14 is offline
Default oil strainer crush gasket
trying to order a crush gasket for the oil strainer on the io-390. The Lycoming parts catalog doesn't seem to show one. Is this a Lycoming error?
https://ibb.co/qmsYKPp
RV-14A flying 350 hrs
Old 03-07-2020, 07:28 PM
Tandem46's Avatar
Tandem46 Tandem46 is offline
If you’re talking about the suction screen, your link does show one. “18” right below 19.
RV-7 Flying since 2004
1,100 hrs+
Old 03-07-2020, 08:01 PM
Exclamation Warning
Clicking on the link in post 1 will attempt to load a program called "Margefrick" or something close.
Old 03-07-2020, 08:02 PM
isn't item 15 the plug which holds the suction screen in? It has different safety wire holes than item 19. Shouldn't the crush gasket be between items 15 and 14?
Old 03-07-2020, 08:04 PM
Mike, The link is to the Imgur image hosting site
Old 03-07-2020, 08:51 PM
The image was up there for a short time, then the computer went into a loop of install this, or not--------clicking no, or Xing out only restarted the loop.
Control Alt Delete finally got me out of it.
Old 03-07-2020, 10:01 PM
RV8JD's Avatar
RV8JD RV8JD is offline
There is one for the oil suction screen on the IO-360-M1B, Item #14 below.
But note that the 1.00" I.D. Annular Gasket, Lycoming Part Number 06E19769­-1.00, is Item #14 for the IO-360-M1B and Item #18 for the IO-390. And the plug LW-12545 (Item #15 for the IO-36-M1B and #19 for the IO-390) are the same between the 2 engines.
Carl N.
Arlington, WA (KAWO)
RV-8, 715 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 03-07-2020, 11:50 PM
yeah, thanks. Looks like the 390 has a couple of additional parts vs. the 360 (items 13 and 15 on the 390 drawing).
For some reason they didn't show the 390 plug and gasket in line with the suction screen like they do on the 360
Has anyone here removed the screen from an IO390? are those 2 parts (13 and 15) attached to the screen when you remove it?
Actually, looking closer at item 15, it looks like an optional plug to replace the standard cap to which you can attach a hose for some other purpose
Old 03-08-2020, 12:13 AM
OKAV8r OKAV8r is offline
AN960-16 ??
Old 03-08-2020, 08:33 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Flat washer
Originally Posted by OKAV8r View Post
AN960-16 ??
AN960 is a flat washer. AN900 is an annular copper crush washer. If you want a 1” ID you would get the AN900-16.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 400+
2020 Dues Paid
The Dues Paid note is a reminder for me
