Old 02-13-2020, 08:40 AM
Mich48041 Mich48041 is offline
How about using a "conduit bushed nipple" available at hardware stores.
A google search will show pictures.
Joe Gores
RV-12 Flying
Old 02-13-2020, 09:16 AM
Brdog42 Brdog42 is offline
Joe,
I was just looking at those yesterday. I don’t know what I don’t know, yes? I couldn’t find any made of steele. Either by description or magnet. I know my magnet works as now my ATM card doesn’t. Most of the items were listed either as zinc or galvanized. Is it solid zinc, or coated in zinc. Zinc melts around 790’F. So, if solid zinc, it’s not durable enough. Then the galvanized stuff can gas off nasty stuff. So why not avoid that entirely? The zinc part was only $.99, so I may pick one up today and put it through my friends torch to see what happens.
BTW, my Cessna 150 was built with a galvanized firewall and had a sound blanket on the back side/interior of the firewall. Plastic coated with what looked like fiberglass sandwiched between the plastic. Replacement firewalls are stainless steel. But how many 150s have an engine fire? Although, I think I was close. When I added a JPI fuel flow meter... I found the great looking fire sleeved fuel hose was extremely brittle. With very little handling, it leaked 100LL all over. Glad I added a ff transducer, new fuel line and avoided a time bomb.
Edit: stupid me. If it is solid zinc or coated, it doesn’t matter. It’s the zinc which gasses off on galvanized steel which is nasty. So, I’ll avoid either. YMMV. Tim
Tim
1973 A150L sold
RV-6A restoration in progress
KCHD AZ
‘’’’’’’’’’’__|__
*>—O-(_)-O—<*
Old 02-13-2020, 09:29 AM
Default Thanks
Dan, thanks for answering my question. Thanks to all for posting experiences.
I’m rebuilding an -6A. A solid build but no Bronze Lindy. Flown, but sat in a back corner of a hangar for 15 years. I ran into the “Layers of an onion” thing. “While the wings are off and the tail is off and the engine is off, etc. I might as well get that fixed/changed/uncomplicated...”
The de-construction stopped in December. The new Vans -A engine mount and nose gear are on. I have a slick firewall. So this is a timely thread. Going the fiberfrax / SS foil route, as well.
Again,a big thanks to all those who’ve tested & shared knowledge on firewall forward.
Tim
1973 A150L sold
KCHD AZ
‘’’’’’’’’’’__|__
*>—O-(_)-O—<*
Old 02-13-2020, 10:07 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
I used a couple of these I had without the set-screw... I reversed the nut and added fire-sleeve. Used for wiring and engine controls.
https://encrypted-tbn0.gstatic.com/i...2n9DFwl6xFCM8m
For bowden cable I drilled a couple of 3/8" hardware store bolts...
~600+ hrs... so far so good...
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 02-13-2020, 11:33 AM
WingsOnWheels WingsOnWheels is offline
Many of the home-depot conduit parts are zinc, so no good at all for this application. If you find them in steel, they should work well enough.
I made my own, 4130 tube welded to a base plate. The wires are wrapped with firesleeve tight enough that it is a job to get the sleeve inside the conduit. Then another firesleeve is on the outside of the conduit. a hose clamp holds it on the conduit and a stainless band clamp to the bundle.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec), but donated early in Sep'19.
Old 02-13-2020, 07:22 PM
jrs14855 jrs14855 is online now
Default Conduit
Non RV. I made my own same as Colin P but all stainless. Stainless machine screws and stainless all metal nuts to attach to firewall. In my opinion the long portion should be forward of the firewall and at least 1" long.
Several years ago these were available from the same source as the all stainless cabin heat boxes but I haven't seen them for a long time.
Old 02-14-2020, 05:44 AM
Sam_B Sam_B is offline
Default Thanks
Thanks everyone for their input, I appreciate it. I’ll get to work on fabricating something this weekend
RV-8
Empennage done
Wings 90% done
Fuselage in progress
2019 dues paid
Old 02-14-2020, 07:12 AM
PhatRV PhatRV is online now
I found this on McMaster. This version is all steel and not the galvanized stuff.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Interior work
Avionics Installation -- started
Donation paid through 2020
Old 05-16-2020, 08:32 AM
Default Another quick question
Perhaps this is evidence as to how slow I work, but I originally asked the question about 3 months ago and am finally getting to this. Now that I have a better idea where the wires, cables, and hoses will go, do I need to put firesleeve inside the pass through to protect the wires from the stainless pass throughs, or will the fire barrier seal adequately protect the tefzel insulation from the stainless on the ID of the pass through and limit wire to pass thru relative movement (and thus, abrasion of the insulation). Just wondering how big to bore the inside diameter, assuming smallest hole to accommodate the hardware going through it is best.
Comments from the brain trust?
RV-8
Empennage done
Wings 90% done
2019 dues paid
