Old 12-15-2019, 11:07 PM
rapid_ascent rapid_ascent is offline
Default Prepping for Interior Painti w/ Jetflex WR
Iím getting ready to paint my interior with Jetflex WR. Most of my parts are primed with Akzo. Iím wondering if there are any suggestions before I start. My plan is to just go over all the surfaces with maroon scotchbrite, and then wipe it down with lacquer thinner. Do I need to prep the plastic Naca vents? Any suggestions about the prep or painting process would be helpful.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 12-15-2019, 11:29 PM
az_gila's Avatar
az_gila az_gila is offline
Originally Posted by rapid_ascent View Post
I’m getting ready to paint my interior with Jetflex WR. Most of my parts are primed with Akzo. I’m wondering if there are any suggestions before I start. My plan is to just go over all the surfaces with maroon scotchbrite, and then wipe it down with lacquer thinner. Do I need to prep the plastic Naca vents? Any suggestions about the prep or painting process would be helpful.
That's exactly what I did over the same Akzo primer, but wiped it down with acetone after the maroon scotchbrite. Lacquer thinner should be fine too...
The plastic NACA vents should be OK with the same process.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-16-2019, 08:40 AM
Thermos's Avatar
Thermos Thermos is offline
That's all I did as well. I've found that once it's fully dried, JetFlex WR is really tough stuff and even sticks well to some surfaces that aren't so well-prepared.
Dave
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
Old 12-16-2019, 09:52 AM
motodave motodave is offline
Any experience over rattle can etch primers assuming the surfaces are once again lightly scuffed and cleaned?
Dave
RV7 Slider N732DH resvd
Empennage 100% Complete
Slow build Fuselage in process
Then QB Wings
Littleton, CO
Photo log: https://flic.kr/s/aHsjN4AZyr
Old 12-16-2019, 09:55 AM
Mark33's Avatar
Mark33 Mark33 is offline
Default Primer wash
My quick build kit came with that primer wash....or whatever itís called. Do I need an additional primer on top of that or just scuff that wash primer up with the maroon S.B. as mentioned above and apply the Jet-Flex directly to that?
Mark H.
RV-7- IO-360, EFII, Whirl Wind C/S, (Built and sold)
RV-4- O-320, Catto three blade, P-Mags (Sold)
RV-8- IO-360, Hartzell C/S (Flying)
RV-7- (Building)
