Ian
Member
I can't figure out the way I should read the plans for attaching the Z brackets to the web spar.
Do I need to understand the normal pattern is as per DWG 7 (section G-G) : only 2 bolts ?
If yes, why should it be different at root rib sta on DWG 12 (section C-C) with 2 bolts + 3 rivets ?
