Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 06-24-2019, 06:57 PM
WingsOnWheels WingsOnWheels is offline
Originally Posted by fbrewer View Post
Members,
I had another suggestion that I would like your thoughts on.
Add 3/16" to 1/4" spacing between the engine mount and the dynafocal mount.
What are the engineering issues with this, other than a longer moment arm of the motor (nominally 1/4" more forward)?
I dont think that would work since the mounts converge at an angle. Would probably be safer to space out the entire mount from the firewall, but that could cause other issues as well.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec), but donated early in Sep'19.
Old 06-24-2019, 07:43 PM
Tdeman's Avatar
Tdeman Tdeman is offline
Default Screwless Spinner?
Is it the flange on the bulkhead or the web of the bulkhead that's interfering with the cowl?
If it is in fact the flange, and you only need to remove about 3/16" for it to work, you could convert the aft (or both) bulkheads to the "screwless spinner".
Then, you could trim about about 3/16 of the spinner off the back (without worrying about edge distance in the glass), giving you the needed clearance relative to the cowl.
That being said, a screwless spinner may not be any easier than cowling rework, but at least you'll end up with a sleek font end
This post brought to you in part by, pour-over coffee, sleep deprivation, and a need for speed.
Opinions expressed in this post do not necessarily represent those of my employer.
Old 06-25-2019, 11:13 AM
rvsxer rvsxer is offline
Originally Posted by agirard7a View Post
I had a similar problem with my cowl when I converted from a nose wheel to a tail wheel. The engine Mount was shorter which created a tighter space between the spinner and cowl. Vanís allowed me to put spacers between the mount and fire wall. (Aprox 3/16Ē). I also but an 1/8Ē spacer between the prop spacer and the aft spinner plate. Hope this helps. Check in with Vanís to make sure.
I put spacers between the mount and firewall when I converted from a Sensenich FP to a Hartzell. Worked fine.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
Manager - Panel Design, SteinAir, Inc.
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 06-25-2019, 10:27 PM
fbrewer fbrewer is offline
Mike,
Thanks for the info. You might find this a coincidence, but the RV-6 we are converting is N664SB
It is a small world.
Your suggestion is a good one.
