Old 06-17-2019, 07:51 PM
kbalch's Avatar
kbalch kbalch is offline
Live and learn. Might be a regional thing. So long as we can all lift our engines, though, Id be content to call it by either name.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494)
Std. kit begun 5/18 - Stick grip wiring, wheel pants, gear leg fairings, and misc. other pre-airport finish-up tasks
Old 06-17-2019, 08:17 PM
Plummit's Avatar
Plummit Plummit is offline
Originally Posted by dreed View Post
yeah, it's pretty common vernacular in the automotive world to call an engine hoist a cherry picker too.
Just don't call it "Conditional", You'll never hear the end of it! ;-)
-Marc
N814RV
2019 Donation Made
Old 06-18-2019, 08:49 PM
wjb's Avatar
wjb wjb is offline
Originally Posted by MED View Post
I raised the pallet off of the ground onto, I think, 4x4 inch blocks. Whatever will accommodate the legs of your engine hoist. I used a lever (actually, a mattock) to lift one side of the pallet at a time onto the blocks. Then, it was easy to position the hoist directly over the engine.
Exactly what I did; slowly raise up the pallet on blocks, roll the engine hoist under, suspend. The the real challenge was getting the box off. Lyc's pour-in-place-type foam packaging did a good job of molding the box to the engine. I had to cut away part of the box to get the engine out.
BTW, this is my understanding (Left coast perspective). Looks like you can hoist an engine with a cherry picker, but not pick cherries with an engine hoist.
Engine hoist:
Cherry picker:
Bill Bencze
N430WB RV-7 #74152, tip-up. Final assembly.
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2020 donation happily made
Old 06-19-2019, 04:38 PM
Stockmanreef Stockmanreef is offline
Ok--I have the engine off the pallet and on cinder blocks. Is there an easy way to pick up and rotate the engine 180 degrees. It is currently backwards. I would like to minimize rolling the engine around when hoisted off the ground. Should I raise the engine remove the box and then lower down on something with wheels? Then I can turn the engine around. Maybe these are stupids questions, but I am lifting a $38K thing off the ground and would like to avoid mishaps.
thanks
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14a (serial number 140073)
N73XP (at least that # reserved now)
Old 06-19-2019, 06:15 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
thanks
ken
Backwards to what? The plane? No reason to do anything until you're ready to mount it, but then...
It's an engine hoist. It's designed to safely hoist engines. If the engine is properly attached to the hoist via the chain, it's not going anywhere you don't make it go...move slowly, watch what you're doing, and it'll be fine.
2019 Dues paid!
Old 06-19-2019, 07:26 PM
Mel's Avatar
Mel Mel is offline
If I understand the question, it sounds like you should just twist the lifting chain 180 before you hook it to the engine lifting ring. Then lift the engine slowly while someone holds the engine so it doesn't spin rapidly.
Is that what you are talking about?
A&P/BGI/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 06-19-2019, 08:59 PM
I figured out my non-issue. Just not thinking it through.
Ken Stockman
Midland, MI
Old 06-19-2019, 09:07 PM
Engine hoist:
Cherry picker:
They're pretty similar in the way the main boom articulates, so I see how the cherry picker hoist got its name.
Doug
RV-9A "slider"
Flew to Osh in 2017, 2018 & 2019!
Tail number N427DK
Donation made for 2020
Old 06-20-2019, 08:13 AM
Ken,
If something comes up and you need a hand, let me know. I am in Okemos, so not that far away and I will come up. I remember when you got your kit several years ago!
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 06-20-2019, 09:52 AM
Default More importantly..
Picking Cherries or lifting engines..make sure you have your oil pressure fitting in place!! Don't want to pick more cherries than you need too!
Bill E.
RV-4/N76WE
8A7 / Advance NC
