Old 06-01-2019, 12:39 PM
Walt's Avatar
Walt Walt is offline
Originally Posted by chris mitchell View Post
So we connected the G5 to reference ASI. Consistently across speeds from 200kts down to 60kts, it was 2-3 kts at least out of agreement except at about 110kts. We have opted to ask for a replacement unit. It’ll be interesting to see how that stacks up.
Chris
I don't think you're gonna get much better than that as far as accuracy, TSO'd AS indicators limits generally range from 2 at the low end to 7 mph error at the upper end.
If you were to ask me I'd say that's pretty darn good at 2-3kts error, most analog instruments are double that.
And is a few knots really that important?
As far as the altimeter matching your transponders output that's meaningless from an accuracy standpoint.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-04-2019, 09:24 AM
chris mitchell chris mitchell is offline
"As far as the altimeter matching your transponders output that's meaningless from an accuracy standpoint. " I totally take your point!
The altimeter is at least 10 years old, over 550 hours on it. Maybe its time for a check and recalibration if needed. How often should that be done, or is it simply a matter of noting if the indicated altitude on the ground is appropriate for the QNH?
Will report back on the G-5 in due course. THe instrument itself and the kit for intallation with the magnetometer are nicely done.
Chris
Chris Mitchell
Repeat offender;
RV-8, QB, built, flown 150 hours, sold;
RV-4 - attempted repair, rebuild and remediation - abandoned and junked ;
RV-4 fuselage and wing kits - both at QB stage;
2015-2018 dues paid!
Old 06-25-2019, 01:32 PM
Default It was the G5!
So - we got a replacement G5 unit. Installed it, flew it. Agreed with the ASI within 1-2 kts. So we conclude it was the original G5 unit.
Now we are grappling with the GMU-11. Found some helpful stuff on another thread, so testing is in progress.
Thanks for the comments and suggestions, much appreciated.
Chris
Chris Mitchell
Repeat offender;
