Go Back   VAF Forums > Main > Safety
Old 06-23-2019, 08:24 PM
Eddie P's Avatar
Eddie P Eddie P is offline
Default Speaking of Jam Nuts...
Hi guys, I’m looking for opinions and techniques.
I have been quite attentive to my “nuts” on preflight thanks to the great information here and the video posted to Youtube featuring Vic Syracuse speaking on the more notorious leisure attitudes around RV preventative maintenance, care and feeding. Jam Nuts were an emphasis area among others.
So lo and behold, after many recent flights thinking, “when am I gonna find a loose nut” I saw something different. One of my torque paint stripes on a Jam Nut was partially missing. Sure enough, the jam but on the outer left elevator backed off a few degrees after the last flight. I tightened it up before flight. And admittedly, it was an awkward fit for the wrench I was using.
I would love to hear and see how you guys “keep your nuts in check” without buggering up the nuts or airframe with wrenches. Also, what torque and how do you measure it?
I did not build my 8 as much as I wish I could have. So my question comes from a non-builder reference. On the pre buy inspection there were a few jam nuts that had started backing off in the tail so they were re torqued and striped for easy identification of possible backing off in the future. So this jam nut has about 20 hours of service before moving again. Admittedly, I have done several stalls and incipient spins to get used to the stall and departure handling of this particular airplane so the tail has been worked a few times in addition to treating the plane to about 50 landings since the nuts were torqued and striped. Interesting, none the less.
Flying is Freedom
RV-8 IO-360 CS Prop KRNO
VAF Support / Dues Paid Through DEC 2019
Old 06-23-2019, 09:14 PM
Hey Eddie,
On all my jam nuts, I applied LocTite, torqued them to final spec, then applied Torque Seal, and nothing has budged in 3.5 years. It is difficult to get a wrench securely on these buggers (especially through the openings in the elevators) so I modified an offset box wrench, cutting off at least the outer third of the box...think flare wrench for brake line fittings. Works like a charm.
Doug
RV-9A "slider"
Flew to Osh in 2017 & 2018!
Tail number N427DK
Donation made for 2019
Old 06-23-2019, 09:18 PM
rv7charlie rv7charlie is online now
Are you speaking of actual jam nuts, as used to secure a rod end bearing ('heim joint') on a pushrod, or a nyloc nut, used on the bolts inserted through brackets and the ball of a rod end bearing?
Originally Posted by rightrudder View Post
Hey Eddie,
same for me.
Old 06-23-2019, 11:11 PM
Eddie P's Avatar
These particular jam nuts (of many types thought the plane) are the nuts that screw down onto the elevator spar (and attach to the rod end thread. I think these jam nuts pre load the rod end thread so it has support on both ends of the spar). The rod end threaded bolt that the nut is mounted to creates the elevator side of the elevator to stabilizer flight control hinge mount. These are also used on the rudder.
Flying is Freedom
Old 06-23-2019, 11:17 PM
bruceh's Avatar
bruceh bruceh is offline
Just get a cheap set of deep offset box wrenches from Harbor Freight. Take the cutting wheel to the end of the box part of the wrench to open it up enough to get it over the threaded portion of the rod end bearing. The offset allows you to get it on the jam nut and have the handle of the wrench be able to clear the skins of the HS/VS/Rudder.
https://www.harborfreight.com/8-piec...set-32041.html
Bruce Hill
RV-9A N5771H flown over 600 hours!
http://www.overthehills.com/RV-9A-Project
APRS Tracking for KJ6YRP and New Flying Blog
2019 VAF donator
EAA Tech Counselor
Old 06-23-2019, 11:55 PM
Eddie P's Avatar
Thank you for that link and description. Very doable. How do you know / verify the proper spec for torque? I'm assuming in this case it's a "TAR" torque device (That's About Right)?
Flying is Freedom
Old 06-24-2019, 08:29 AM
Torque value on a fastener can be measured in many different ways....
A wrench such as the one in the link, coupled with a spring scale and some simple math can give you an accurate torque reading.
Scott McDaniels
Hubbard, Oregon
Old 06-24-2019, 08:05 PM
Eddie P's Avatar
Great idea, thanks. I'll have to see if I can google a few images of that type of torque contraption.
Flying is Freedom
Old 06-25-2019, 07:21 AM
FinnFlyer FinnFlyer is offline
Spring scale = fish scale.
Hook fish scale to end of wrench at 90 degree angle.
Torgue = distance from center of nut to fish scale attach point x fish scale reading.
Or Torgue required / distance = what you want to the fish scale to read.
Finn
RV-4 -- Building
N46AZ RV3-B Mazda 13B FI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
