Old 10-09-2014, 10:49 PM
Gandalf Gandalf is offline
Originally Posted by txaviator View Post
I started by using some that were paper-based. When trying to remove them, they tear and it is MUCH harder to remove them
txaviator... I am setting up even now to seal the rivet heads. My current plan is to use blue masking tape with holes punched out, and it sounds like I should perhaps add plastic hole reinforcements to my paper tape, correct?
Also, what did you do with the flush rivet heads. Perhaps just fill in the holes?
Jeff
Old 10-15-2014, 11:14 PM
gossend gossend is offline
Default Masking rivet heads??
You guys are shaming me with all this prettiness. Heck, I just swabbed each one with a Q-tip and pro-seal. A little ugly, but functional...just like my tank!
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with G3x Touch
Old 10-16-2014, 04:35 PM
txaviator's Avatar
txaviator txaviator is offline
Jeff
Sorry for the delayed response. I'm so busy at work these days that I really don't have a chance to check-in here very often.
The blue tape with holes should work just fine, without the reinforcements! The plastic hole reinforcements are a bit difficult to find, with the paper versions being the norm. But the plastic ones work great IF you can easily find them!
It worked great on my RV-12 build, and yes, on the flush rivets, I filled the holes but also the area surrounding the rivet. It makes everything look uniform.
* DISCLAIMER: my process worked great with the circular reinforcements....but I stole the idea from DancesWithBassets
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 10-28-2014, 03:27 PM
Hi Gary... Yup. I removed the blue tape as I worked and it worked fine.
Jeff
Old 10-28-2014, 11:19 PM
txaviator's Avatar
Jeff
That's FANTASTIC! Glad it worked out well for you!
Gary Robertson
Arlington, TX
Old 03-02-2016, 03:07 PM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default sealing rivet heads
I got inspired by that idea.
hope it'll work out well without messing much with proseal beyond the masks.
I use a generic electrical insulation tape
Chris, RV-12 HB-YSC
Preparing for final assembly
Facebook: http://www.facebook.com/magic.carpet.aviation
12-Town:http://12town.com/profile/Chris
=VAF= dues paid for 2018
Old 07-01-2017, 08:15 AM
Tacco Tacco is offline
Anything disadvantage to just sealing from the cockpit side? Sure would make it easier to clean the engine side of the firewall. Would look better too.
Old 07-01-2017, 01:09 PM
DanH's Avatar
DanH DanH is offline
Yeah. If the firewall ever has to deal with a fire, the sealant on the inside will probably ignite. Think how much you will enjoy polysulfide sealant smoke.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-01-2017, 09:48 PM
Fuel tank sealant is flammable. I set a sample on fire with a propane torch. When the torch was removed, the sealant kept on burning and kept on giving off obnoxious smoke.
Joe Gores
RV-12 Flying
Old 07-09-2017, 02:08 PM
rongawer's Avatar
rongawer rongawer is offline
Default Sealant
Instead of tank sealant, or Pro-Seal, a better sealant is BioTherm 100. It's not flammable and hardens with a paintable finish and will withstand 2000ºF, about 125º more than burning Avgas.
Another brand line is RectorSeal, but it's made by the same manufacturer as BioTherm and has the same functionality, just branded differently for different industries.
Both are available online, although I got a tube with my heater bypass valve from www.planeinnovations.com.
Also, the Avery poly-vinyl hole reinforcements are about $1.50 for 200 on Amazon.com...work great.
Ron Gawer
- RV12, N975G, SN 120840, Build in progress...finishing up.
- BE58, N1975G, stimulating the economy one flight at a time.
