Old 07-16-2017, 12:00 AM
drone_pilot drone_pilot is offline
Smile Oshkosh Newbie
I wasn't sure of where to post this so here goes....
I think I'm going to fly solo to Oshkosh this year, weather permitting. I've been studying the NOTAM and practicing holding altitude +/- 50' at 90 kts and landing on a given spot on the runway. It was really turbulent here today with low ceilings and some TS in the area. Today's performance has me wondering if I'm up to the task. Airspeed was varying wildly in the bumps and by the time I thought I had it under control, I had gained or lost 100 or so feet. The weather today was just not cooperating. The fixed pitch prop on my 7A seems to increase the difficulty level as well because as the nose on the airplane pitches up or down, the prop rpms vary. Any helpful technique or input is appreciated!
At Oshkosh, after landing on runways 36/18 LR, is the exit procedure the same as 9/27 where you roll into the grass to the left or right as soon as you are able? That is on the arrival procedures for 18/27 but see no mention of it for 36/18. There is talk about taxiing west of 36L etc but nothing I have seen stating how to exit the runway.
Should I purchase tickets and passes before I get there or is it preferable to get them upon arrival to OSH? I'll be in HBC if that helps.
Any war stories that help me know what I am getting my self into are appreciated also!
Ben
RV-7A Tip Up Airworthy on 12/20/2016
Pondering what I should build next!!!
Old 07-16-2017, 05:39 AM
I've never been asked to taxi onto the grass beside 18/36 and have never seen anyone else do that either. I have done it/seen it done on 9/27.
As far as tickets go, I buy them after I arrive. Between weather, work and family issues, and the occasional mechanical problem, there is too much risk involved for me to buy tickets before arriving.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 07-16-2017, 05:41 AM
MikeyDale's Avatar
MikeyDale MikeyDale is offline
No need for tickets or passes, just the HBC sign in the window, they will fix you up when you get there. Last year I had to slow down to 70kts on downwind coming in at 1:00 PM on Saturday before the show started. If you cant keep separation with the guy in front of you just peel out and start over. I plan to get there early on Saturday morning this year to avoid the heavy traffic but weather can cause everyone to get there at once as we all know. It is a lot of fun flying in and camping!
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
First Flight https://www.youtube.com/watch?v=QqgxhWH3pqA
Build Blog http://mikesrv7.blogspot.com/
Dues Paid
Old 07-16-2017, 05:55 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Also work on really tight traffic patterns and be comfortable with those.
RV-8 (steam gauges), RV-9A at KSAV (Savannah, GA; dual screen G3X with autopilot, GTN 650)
Previously RV-4, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2018 dues paid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 07-16-2017, 06:28 AM
Practice with the aircraft loaded as it will be on arrival. Getting there early in the day will be a great help as the traffic is much reduced. Plan on stopping an hour out for a break, check fuel etc. at that point you will likely know which runway is active. You can listen in to ATC live, https://www.liveatc.net/feedindex.php
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 07-16-2017, 06:36 AM
BigJohn BigJohn is offline
Flying into Oshkosh solo for the first time is not something I would advise. Things can get very hectic in a hurry, with constant radio chatter, last minute runway assignments/changes, short approaches, spot landings, and flying much closer to other aircraft than you are accustomed to.
If you decide the risk is worth the reward, you will need to memorize the NOTAM instructions for all runways, because you will need your eyes outside the cockpit at all times. Try to pick an arrival time when traffic is likely to be lighter. Go only in really fine VFR conditions.
As to Runway 18/36, you will not be rolling into the grass, you will be using a taxiway (there are a lot of them), or landing long and high speed taxiing to the end.
Personally, even though I have landed at Airventure many times, I always want that extra set of eyes and ears aboard.
VAF paid through 10/2018. Best bargain in town.
Old 07-16-2017, 06:43 AM
bret's Avatar
bret bret is offline
Reminds me of an advanced motorcycle safety course I took, everything was performed in a big lot under 40 MPH, an eye opener for sure, easy to go high speed and straight, but going slow and maneuvering around obstacles is a lot more difficult, practice slow flight at a safe altitude might help.
2018 gladly supported
Old 07-16-2017, 06:52 AM
rolivi's Avatar
rolivi rolivi is offline
Note that 18R/36L only exists for about 1 week per year. Normally it is known as Taxiway Alpha.
The tower guys do a great job handing out rapid fire instructions WITH reminders so you'll be told if they want you turning or not. One less thing to remember.
Just remember to fight your urge to respond to the radio!
Rob
RV-6A (Purchased)
2018 Dues Paid
Old 07-16-2017, 07:05 AM
for me it is all about how busy the arrival is. getting there early is my first plan. otherwise if it is a bees nest then just land and wait awhile.
good luck. Mecca awaits.
TURBO YES =VAF= Payed Jan2018
RV6-A 4,950 hrs, R-44 1,500 hrs, Helicycle 280 hrs, gyro sold,35,000 miles flown in 2015
Old 07-16-2017, 07:14 AM
Jesse's Avatar
Jesse Jesse is offline
Last year we arrived on Sunday. The Ripon arrival was closed and there were at least a hundred planes holding around the 2 lakes. We landed in Fondulac and waited. When we saw the ADS-B traffic departing the lake, we loaded up and took off. We were one of the first planes into Ripon after he lake hold cleared out. There is always something exciting, but stay on your toes and don't be afraid to peal out and rejoin at Ripon.
352-427-0285
jesse@saintaviation.com
