Old 07-15-2017, 06:04 PM
Tankerpilot75 Tankerpilot75 is offline
Default Need Help: GTX 335 setup
I just finished installing my GTX 335 with internal gps but have some error messages.
On the main screen is says "MSG NO 1090ES TX"
I went to the message screen it said:
"ADS-B POSITION INPUT FAILED"
"PRESSURE ALTITUDE FAILED"
I believe the "ads-b position input failed" message is because the airplane was in a steel hanger because both my 430 gps' also said RAIM IS NOT AVAILABLE. However my lower 430 also said "NO ALTITUDE INPUT IS BEING RECEIVED which would correlate with the second message of the GTX 335.
I just removed a GTX 330 which was working fine but it was non-ES. My RV has dual GRT Horizon WS EFIS' with an ARINC 429. My 430s are non-WAAS. I assume altitude information was sent to the old 330 transponder from the EFIS through either the ARINC or RS232 connections.
The other day I asked the "G3Xpert" for programming help and he referred me to their field service engineer. The field engineer's response basically was "each field entry is explained in the preceding pages" of the various sections of the manual. Not much help from Garmin!!!
I'm pretty sure my "problems" are programming related and how I misprogrammed "INTERFACES" and possibly "SENSORS."
My old GTX 330 was set at:
429 Input
Channel 1: Speed - Low; Data - ADC NO ALT
Channel 2: Speed - Low; Data - GPS/FMS
Channel 3: Speed - Low; Data - OFF
429 Output
Channel 1: Data - OFF
Channel 2: GARMIN W/TIS
RS 232 Input
Channel 1: OFF
Channel 2: ICARUS ALT
RS 232 Output
Channel 1: OFF
Channel 2: OFF
Of course the manual for the GTX 335 labels RS232 and ARINC 429 settings with totally different names and the explanations don't help me translate from one label to another. If anyone can give me some guidance I would really appreciate it!
Jim Harris
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, Garmin 340, 335, Dual 430s, Stratux hard wired to WS, Dynon D10A (backup EFIS)
Retired - Living the dream - And going broke!
Old 07-15-2017, 07:57 PM
Jesse's Avatar
Jesse Jesse is offline
The 335 has a huge maze of menus and settings. Get a chart from the shop that sold you the unit and make sure all of the settings are right. I can set up a Stratus ESG in about 2-3 minutes. The 335 takes about 20-30 (only slightly exaggerated).
352-427-0285
jesse@saintaviation.com
Old 07-15-2017, 08:19 PM
Steve Koziol Steve Koziol is offline
Default Transponder set up
Another option is to call the Garmin Experimental number direct line and have one of the techs walk you through the menu pages while sitting in your plane. I did this with my GTX345 set up.
Steve
RV9A
Old 07-16-2017, 08:17 AM
Default Got re installation manual
Jesse
I had Stein email me the installation manual last week. Unfortunately it was Saturday afternoon by the time I finished the install and Steinair was closed. I will call them first thing Monday morning to get their assistance while I'm sitting in the airplane.
I agree the installation menu on the GTX 335 is exhausting. The manual would have helped if better explanations of the menu choices were provided. Conversion of 330 menu choice names to 335 menu choice names leaves a lot to be desired.
I need to get the issue resolved quickly so I can test fly Monday. On Tuesday I fly to San Antonio to attend a family event, return to OKC Wednesday/Thursday and fly to OSH Saturday with a group of friends. Busy week but didn't want the installation delayed since I want adsb out and in for these trips into higher traffic areas. I will use FlightBox to feed my EFIS and iPad for adsb IN traffic.
Old 07-16-2017, 08:54 AM
uk_figs's Avatar
uk_figs uk_figs is offline
Default Dumb ADSB question
As I am part of the group that will be flying with Jim on Saturday, if you are flying in a group with someone with ADSB OUT will the traffic warnings from ADSB IN equipped aircraft be continuously triggered (in my case GDL 39 and 796), can this be filtered somehow?
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 07-16-2017, 09:47 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
I'm still in the process of installing the GTX335 in my Tiger, but the on-line documents come with a "setup guide" and an ".exe" file for a PC. Garmin gives you access to these documents online when you register your unit.
Do you have a PC laptop available? If so it seems like the GTX335 can be fully programmed step by step via the provided USB port.
You do have the USB input connected don't you?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-16-2017, 01:59 PM
Gil,
I had Steinair build me a conversion harness so I do have the USB port wired into the GTX 335 (but it's a different type of USB harness than I'm use to seeing). It's a good thing I had Steinair build me the harness because there was a lot to this installation that I didn't understand and wouldn't have accomplished if I'd attempted to do the wiring myself (Example: Wire in a USB hub and Keep GPS Alive wiring). Best money spent!
I have not registered the unit yet (thinking I'd wait until I installed it) but again this lack of knowledge (understanding) on my part identifies the challenge of a self installation for a rookie. Electronics is not my strongest suit but being "cheap" is what makes me attempt things like this. Most of the time it works out because tenacity keeps me at it until I figure things out (usually with a lot of questions and help in between). But this is what I like about RVs and the VAF community and also the education that projects like this provide.
I didn't build this RV (bought it two and a half years ago from the original builder) but have since fixed a large number of "build quality issues", installed several electronic enhancements such as wiring up adsb "in", moving magnetometers because the builder placed them too close to the radio antenna resulting in serious heading issues, replacing a failed autopilot controller, removing manual trim and installation of electric elevator and aileron trim with Pat Hatch's Ultimate Trim Hub controller, removal of two button grips and installation of dual five button military style grips with coolie hat trim, transponder ident, PTT and CPTT, A/P connect/disconnect, flaps, and freq/comm swap using a lot of the functionality that my Aerotronics panel had previously been wired for.
Often these projects start out with a simple idea and very conservative time line and grow into major projects because I didn't initially recognize the complexity of the idea in the beginning. I just bring this up because it demonstrates my willingness (maybe stupidly) to tackle projects that I deem important.
So while I'm not the original builder I still use the RV experience to expand my knowledge and keep myself busy in retirement. Long answer to why I'm having trouble understanding what the installation manual says and why programming has been such a challenge.
G3Xpert saw my thread on this and sent me another email which helped my thinking process a little. I'm reviewing the old 330 setting pictures I took before removing the unit, cross referencing them to his email and the manual, and will look at my EFIS general settings to see what serial port feeds data to the transponder. Hopefully doing these steps and calling Steinair in the morning when I'm at the plane will quickly resolve this crisis for me.
Once again the VAF community and its advertisers prove why these aircraft and associated avionics are so great!
Old 07-16-2017, 02:13 PM
Figs
Fig (Dennis and Steve say I should call you "Shredder"),
I don't think me having adsb out near your airplane will be a problem. In fact it should make your adsb in work better. Ads-b in is triggered (I'm told) by an adsb out signal near you. The closer the out signal the more reliable the adsb in position is to your aircraft. Remember when your flying in rural areas you often don't get adsb in traffic information because your not near an adsb out signal. My aircraft in the group (I believe) will provide better traffic information to everyone using only adsb in information on their iPad.
Old 07-16-2017, 02:31 PM
az_gila's Avatar
Exclamation You need all of the documents
The IM isn't really enough.
Trouble shooting procedures are in this document -
190-00734-11-GTX335-maint-manual-and -ICA.pdf
Register your unit and get all of the latest documents, it's free and better than getting a single document emailed to you.
Gil Alexander
Old 07-16-2017, 04:33 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Well, "Shredder" sounds like a good moniker also but actually he was christened "Slash" after OSH 2015.
RVBYSDI
Steve
RV9A
Live Long And Prosper! 🖖🏻
