Old 07-14-2017, 08:42 PM
LUKLA LUKLA is offline
Default Fuel tank Air vent.
Just curious.
Is any one has done your air vent differently than just making #30 hole in the fuel cap on RV12 gas tank.
I have heard there is new way ppl are doing but haven't seen any picture or schematic or instruction.
input will be appreciate as always.
LUKLA
Old 07-14-2017, 09:10 PM
Slane Slane is offline
Default Fuel tank air vent
See section 37: http://www.vansaircraft.com/pdf/revi...Section_37.pdf
Scott Lane
Hillsboro, OR
RV12 Completed & Flying 2013
#120043 N728SL
VAF paid 2017
Old 07-14-2017, 09:30 PM
2johns 2johns is offline
I think it is a very good idea to change the fuel vent location as Van's has suggested in 37-01 Rev 5 due the possibility of the hole in the cap being plugged or a new owner being unaware of the hole in the cap, losing the cap, replacing it with a new one without drilling the the vent hole. A possible cause of a disaster. I made the revision moving the vent to the top of the tank. Only problem was that I have an automatic shut off and when it shuts off, a small amount of gasoline would spew out the new vent onto the floor. Why, I do not know. I then moved the vent an inch or so below the top of filler neck and plugged the fitting on the top of the tank using the same vent outlet location on the bottom of the fuselage to solve this problem.
Old 07-15-2017, 11:28 AM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
I recommend having both vents, the new tank and the cap. I initially built mine without the cap vent and was having variable fuel pressure when the tank was filled. Put a vent hole per instructions in cap and no problem the last 100 hours.
Scott- 2018 dues paid
Got medical back, now building a 7A.
RV-12 #120515, 319RV over 200 hours.
1st flight 12/08/15, flew SNF, Oshkosh, Triple Tree & SERFI in year 1!
RV-9A, 536 hours, sold, RV-7 sold, Kitfox sold
Old 07-15-2017, 12:51 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Very interesting....me thinks I'll try that as I've seen changing (lowering) fuel pressure as fuel is consumed (and I know my vent works as fuel runs out if I overfill tank)...
Scott...where would find instructions on how to drill vent hole in cap?
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 07-15-2017, 04:45 PM
Actually I subscribe to the vented cap all by itself. I use 93E10 auto fuel exclusively and donít want a lot of air exchange in the tank. Alcohol is very hydroscopic and will absorb moisture in the air. Also, octane rating for auto fuel will diminish if not stored in a sealed container.
So I run a cap with the small vent hole and have had zero problems in 258 hours. When I did the fuel tank SB I elected to not install the new vent system. Fuel pressure and fuel flow are rock steady regardless of fuel quantity.
Hinckley, Ohio
P/ASEL 1970 Sport Pilot since '04
RV-12 E-LSA #120058 AWC 7/12 Bought Flying 10/15 with 48TT - Hobbs now 317
LSRM-A Certificate 2016
Old 07-15-2017, 05:43 PM
So verdict is Just make # 30 hole in fuel cap and it will do perfect !!!
Thanks a lot Folks.
Lukla
Old 07-15-2017, 06:04 PM
DHeal DHeal is offline
I have the Van's early plan's holes in the fuel cap. It seems to be working fine for me over 500+ hours. Just be sure that as part of your pre-flight that you remove the cap and blow air (breath) through the holes to ensure that they are free and clear of debris, bugs, etc. Also, during outside exposure to rain, I tape a piece of plastic sheeting over the cap that is positioned to keep rain out of the cap area yet would blow away in the prop wash if I were to forget to remove it before flight.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 600+ hours (as of Feb 2018)!
VAF donation through June 2018.
Old 07-15-2017, 07:35 PM
I do the same as David. 600 hours and 5 years later the vented cap still works great.
Old 07-15-2017, 07:42 PM
DBRuth DBRuth is offline
Default Double vent
I also have the new style vent system and the vented cap. I drilled mine to the tap size for 4-40 and then tapped both the cap and the lower plate 4-40, just in case I didn't like the results. I had a couple of flights when I smelled fuel on climb out before I vented the cap, and none since vented. Needless to say I have not had to block off the cap vent. 117 hours total, approximately 100 hours with both vents,no problems.
N412DR
Kit 120797
First flight 8/21/15 what an awesome aircraft!
HOBBS @129.3
