Old 07-13-2017, 11:53 AM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default RV-8 firewall distance from datum
Anyone happen to know the distance from datum for the firewall for an RV-8? I am changing some things around and want to estimate the new cg. Thanks.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donation Made 7/2017
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 07-13-2017, 12:33 PM
Mel's Avatar
Mel Mel is online now
Datum is an imaginary line used for reference only. It can be anywhere you want it. I personally use the leading edge of the wing for the datum because it's very easy to measure anything from there.
Especially on taildragger RVs because in the level flight position, my main landing gear is pretty much exactly on the datum. Makes for VERY simple math. i.e. 0" times anything is 0.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 07-13-2017, 01:45 PM
Bubblehead's Avatar
I agree it is arbitrary and your choice is a good one. I assume you changed the cg limits accordingly since Van's stated limits are measured from his datum?
For my purposes his datum is convenient because he states the distance back to the rear baggage shelf on the -8. That makes it easy to get the distance from datum to rear battery which I am removing. If someone has the distance from the leading edge of the wing to the firewall on the -8 I can figure the rest out since Vans says the leading edge is 70" back from his defined datum.
The one advantage I can see to Van's datum is all the moments have the same sign - all are CW or all are CCW depending on which side of the plane you're looking at. That eliminates a possible source of error or confusion.
Old 07-13-2017, 06:00 PM
Default You are correct.
The 70" from the leading edge is right. Drop a plumb bob there and count down going to the front. Your on the right track. Yours, R.E.A. III #80888
Old 07-13-2017, 06:11 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Per Vans RV8 W&B pdf it would be 70" minus distance from wing leading edge to firewall.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 07-14-2017, 08:21 AM
Bubblehead's Avatar
I should have been more specific. I am not near the plane and won't be able to measure from LE to firewall for a couple of days. I was hoping someone had the measurement handy.
Not a big deal. I'll take care of it Sunday at the hanger.
