Old 07-13-2017, 06:30 AM
dwranda dwranda is offline
Default Anyone with Sam James cowl on a 9 at Oshkosh?
I'm looking to see one and talk to anybody who has a Sam James cowl on their 9. I'm getting close to the end of the fuse kit and need to order the finishing kit. Need to decide on the cowl. I would love to talk to someone on the pros and cons.
9A in progress
Working on fuse
Finish kit ordered
Mattituck TMXIO-360 red gold
Dues paid Dec 17
Old 07-13-2017, 07:18 AM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
Hi Dave, I will be there and I have the James cowl on my 9A. I am usually in the back side of HBC and plan to arrive on Friday evening. Tail number is N1605A.
Darin
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Wings - Flaps/Ailerons
www.DarinAnderson.com
2018 donation sent!
Old 07-13-2017, 07:31 AM
bret's Avatar
bret bret is offline
On the 7a I did the long SJ with a 3" spacer and CS hart. Held on with a full Skybolt kit, no interference with alt or exhaust. Close clearance with the wide angle 200 up front inside with a custom plenum.
2018 gladly supported
Old 07-13-2017, 07:52 AM
airguy's Avatar
airguy airguy is offline
Darin's plane would be a good one to look at, I probably won't make it this year (my plane is in paint right now). I used the long James cowl, 3" prop spacer with Whirlwind prop, Skybolt fasteners, fit great.
Greg Niehues - VAF 2018 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 07-13-2017, 08:35 AM
I agree with Greg. Darins plane is a great one to look at. He was nice enough to make a 2+ hour flight to my airport to let me look and take pictures.
Have fun at AV and say hello to Darin from me. When you start working on your cowl, contact me and I can give you some tips that will help. If you have fuel injection, your life will be easier.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 07-13-2017, 08:57 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Just in case you have not drunk the Kool-Aid yet on the SJ cowl you are welcome to come look me up in HBC if you want to look at a standard Van's cowl as comparison. I have the non-snout lower cowl with snorkel intake (think smooth bottom cowl). I will most likely be somewhere toward the back of HBC also. N number 446RV, red and white RV9A.
RVBYSDI
Steve
RV9A
Live Long And Prosper! 🖖🏻
Old 07-13-2017, 09:12 AM
airguy's Avatar
Let's see, that would be the one with zero ram air recovery factor, correct?
Garden City, TX
Old 07-13-2017, 09:23 AM
RVbySDI's Avatar
Not sure what you are referring to here.
RVBYSDI
Steve
RV9A
Old 07-13-2017, 12:59 PM
dlomheim dlomheim is offline
Default Snout Vs. Scoop
Steve: I think he might be referring to the "snorkle" possibly not having as much ram air pressure going to the carb as a standard Van's cowling w/central scoop?
Doug
RV-9A Mazda 13B, FWF
RV-3A sold
Old 07-13-2017, 01:04 PM
Default Sam James Cowling for 9A
If you end up needing a Sam James cowling, I have a buddy in the OKC area who decided not to use it on his 7A, and would make you a great deal on it I bet.
Doug
RV-9A Mazda 13B/ FWF
RV-3A Sold
