Old 07-09-2017, 06:30 PM
LyleM LyleM is offline
Default Windshield fiberglass question
I'm about to fiberglass the windshield in place on my -8 and want to make sure I don't stick the canopy to it. Instructions say to use a release solution or mylar packaging tap. It would seem that the tape thickness would prevent a nice fit. I'm thinking Plastiease 512B or Meguiar's #8 wax. Any suggestions? Thanks
Old 07-09-2017, 08:10 PM
Mark Dickens's Avatar
If you apply packing tape carefully, it does a very nice job of providing the non-stick you want along with a very thin gap. Pull off a piece of packing tape and try to measure its thickness.
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight November 20, 2016 - Phase One Complete June 1, 2017
Old 07-09-2017, 09:55 PM
Lyle,
I just rebuilt my canopy. It was not as bad as I expected. I used plastic pipe tape and it worked great.
This is how I taped it before epoxy. The plastic tape bends around the curves very much like pin stripe tape. It is 20 mil thick so great protection. A good coat of wax and it popped off great.
Here is the rough finished piece after pulling it off the canopy. I will sand, prime, and then glue it on.
There are a few more pictures of my canopy rebuild here. Hope the links still work!
http://s1245.photobucket.com/user/ro...?sort=3&page=1
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
