Old 07-07-2017, 04:55 PM
LUKLA LUKLA is offline
Default Fiberglass attach to canopy.
Folks ,
What is the best glue to attach fiberglass in RV12 canopy.
-Brand
-Where to buy
-Amount
Thanks for you knowledge.
Lukla
Old 07-07-2017, 05:51 PM
DHeal DHeal is offline
You do not use "glue" to attach an RV-12 canopy. You build up a fiberglass canopy skirt that in combination with the plans-specified "pop-rivets" attaches the canopy bubble to the aluminum canopy frame. I suspect that most of us used WEST fiberglass products at: http://www.westsystem.com/
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 620+ hours (as of Apr 2018)!
VAF donation through June 2018.
Old 07-07-2017, 08:40 PM
I am talking about the fiberglass shield that we build and goes in front of the canopy.
http://www.shop.vikingaircraftengine...ing-Shield.htm
Old 07-07-2017, 09:30 PM
rongawer's Avatar
rongawer rongawer is offline
Use what DHeal said...it's a fiberglass epoxy system.
Ron Gawer
- RV12, N975G, SN 120840, Build in progress...finishing up.
- BE58, N1975G, stimulating the economy one flight at a time.
Old 07-07-2017, 09:54 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
The fiberglass is laid up on the canopy and canopy frame itself. It is NOT built alone then attached like the Viking premade canopy skirt.
Please READ the plans ahead of time as the fiberglass work required is easily a 3-4 hour (or longer ) job. The final shaping and sanding will take a little longer. The plans take you step by step and include templates for the glass layers.
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 260 Hrs on the Hobbs
http://unicom12.blogspot.com/
Click on above for build site
Old 07-07-2017, 10:03 PM
daveyator daveyator is offline
The fairing is built in situ after riveting the canopy onto the frame. It is bonded to the actual canopy bubble when you build the fibreglass. The epoxy is the only "glue" and that is part of the fibreglass system.
I recommend that you really study section34, pages 13-16. Read it through a few times and you should get a feel for what is involved.
The method you link to is nothing like the technique used in the kit assembly instructions.
DaveH
Old 07-07-2017, 11:39 PM
Thanks a lot Folks.
I appreciate your valuable advise as always.
Lukla
Old 07-08-2017, 03:59 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Folks ,
-Brand
-Where to buy
-Amount
Lukla
- West System
- West Marine (2 in the valley Phoenix/Tempe)
- Part 1 105-A resin (32 oz), Part II 206-A hardener (7 oz)
- quick pump kit
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 07-08-2017, 11:09 AM
I took sandpaper and roughed up the surface of the canopy where it must Bond to the fiberglass buildup.
