Old 07-04-2017, 04:28 PM
Greenley's Avatar
Greenley Greenley is offline
Default forward top fuselage skin missing rivet
The build manual on page 41-9 has you leave out two rivets on the rear lower corners of the forward top fuselage top skin. They are marked "not riveted in this section". Well I am way working on panel and engine wiring at this point and have not seen when I am supposed to put in those two rivets. Please help me find what I missed. I have searched and searched.
Bill Greenley
RV-10 standard in progress, working on the fuselage
looking forward to making airplane noises in SW Michigan
Old 07-05-2017, 05:58 AM
rleffler's Avatar
rleffler rleffler is offline
You've got me stumped. I even spent five minutes looking at the plans too. To be honest, I can't remember. It's been too long ago.
I'd be inclined just to rivet them now. If they get in the way of something later, just drill them out. If you have problems sleeping at night, then give Van's a call.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 07-05-2017, 06:04 AM
Super Moderator
Default Door alignment
I think they are used for aligning the doors when you mount them to the cabin top. That's why you leave them open for now.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 07-05-2017, 08:11 AM
Default And...
I had the same question. I went through the plans and was not able to find ANY section that had you rivet those holes...so I riveted them..
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 07-05-2017, 08:20 AM
Greenley's Avatar
Doors done, so will rivet. Sometimes rivets are left out to attach something later, could not how that could be the case here. Thanks for the advice. I have missed things before
Bill Greenley
Old 07-05-2017, 12:35 PM
rleffler's Avatar
That's why I can't remember. I didn't rivet this assembly until much later than the plans called for. This allowed me to take out the whole upper assembly and work on the panel much longer into the build.
Bob Leffler
Old 07-05-2017, 02:57 PM
Greenley's Avatar
That is what I did also, sure helps with access.
Bill Greenley
Old 07-06-2017, 06:23 PM
ClarkieSr ClarkieSr is offline
If your talking about the rivets fire and aft of the door openings don't rivent them until you do the doors. These holes are used to orient the doors and hold it to the fuselage to glue and fit the doors in the cabin opening
