Old 07-02-2017, 12:54 PM
Plummit's Avatar
Plummit Plummit is offline
Default Aarrrg!
Just finished the annual and BFR which ran out the same month. Everything worked normally yesterday. Today the left-hand door wouldn't latch properly. The interior handle goes to about a 45 degree angle then stops. This has the basic 2-pin lock but it also has the "I fly RV-10" flush billet handles on the exterior. Something is jamming the mechanism inside the door (which is sealed). Before I start cutting, has anyone experience this?
~Marc
N814RV
2018 Donation in the mail!
Old 07-02-2017, 03:46 PM
Jesse's Avatar
Jesse Jesse is offline
It's probably the clevis pin that holds the geared rod to the pin. That can sometimes catch on the fiberglass. Try that first. If that's not it, pull the clevis pin on the front and the back independently and see which one starts working with the other disconnected. Narrow it down this way.
352-427-0285
jesse@saintaviation.com
Old 07-02-2017, 04:39 PM
Plummit's Avatar
I think I see what you are talking about on the plans. I'll cut the door open at the interior latch and check it out.
-Marc
N814RV
Old 07-02-2017, 05:32 PM
For those of you who've finished the doors, has anyone come up with a neat way to close the holes you cut in the inside surface of the doors without a permanent patch? I hate the idea of leaving those fiddly linkages in there without a way to access them other than cutting a hole in the door.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 07-02-2017, 08:50 PM
Plummit's Avatar
Default Fixed!
Well it turns out that the builder attached the racks with screws - and no locker. No locktight nothing. The screw holding the aft rack end had backed out until it started hitting the interior of the door. I removed it and replaced with red lock tight. At least he covered the hole with thin glass so it was easy to break out and access the mechanism.
I would have preferred a removable cover plate or door panel.
-Marc
N814RV
Old 07-03-2017, 10:15 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
I have a hole in my painted inner door skins to allow me access to the pin that connects the handle pushrod to the PlaneAround 3rd latch rack. It's probably around a 3/4" hole... enough for me to get the pin and safety wire done up with a needle nose.
I used a flush hole plug cap to cover it. It's just a black circle on my tan doors, and doesn't look bad at all, and it's removable.
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 07-03-2017, 10:19 AM
NovaBandit's Avatar
Here's a picture of my "pin access hole"
Ed Kranz
Old 07-03-2017, 05:00 PM
Plummit's Avatar
Very nice Ed! In my case the offending screw was at the front, behind the interior door handle. The builder had sealed the area with thin glass, so I had to break that out to get access. I'm wondering what's behind the passenger door and the rear outside door handle....
In the above image you can see the screw in the lower left that started to work it's way out. The head is bent forward in this pic.
~Marc
N814RV
Old 07-03-2017, 06:40 PM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
If you have the IFlyRV-10 flush handle, you have something like this on the inside. More opportunity for loose screws. If that rear one comes off you could lose the rear pin and then the door.
Might be a good idea to cut a small hole that can be covered by a plug like Ed's and then scope those screws.
There's also a 1/4" screw in the center, it loosened up for me even with a star washer under it. The next time I'll get to it it will get a pair of Nordlock washers.
Here's how I covered mine so i can get to it. Not too pretty but it works.
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 350 hrs
Old 07-03-2017, 09:05 PM
I'd considered those. Do they A: Stay attached? And B: Not interfere with the internal mechanism?
I'd actually thought about thinning them a little and using rubber cement, pliobond, or some other "soft" adhesive to hold 'em in place.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
