Go Back   VAF Forums > Model Specific > RV-4
Old 06-30-2017, 01:35 PM
SJordan SJordan is online now
Default Rear stick floor opening help needed
Hi guys,
Trying to finish up my floor and can't figure out how big the opening needs to be for the rear stick or front stick. My control surfaces are not in yet so I have no idea how much the stick actually moves. Anyone have any help on how big to make the back and front openings?
Thanks for any help,
Shawn
Pic is just a test piece.
Old 06-30-2017, 06:56 PM
Michael Henning Michael Henning is offline
I don't think there is flooring scheduled for that area. It's been a while, but I think my center bays are open, so I can drop my cell phone down there.
Mike
RV-4 #2750
N654ML
IO-360 200HP
WW150C Prop
1018 lbs
Flying
Old 06-30-2017, 08:13 PM
Mine (purchased) has what appears to be an aftermarket floor shifter boot around the rear stick. Its flange is almost wide enough to reach across the center tunnel.
Old 06-30-2017, 09:16 PM
Go Guy Go Guy is offline
Don't know how big the opening needs to be, but I sure like your N # strap!
Rod Estep
RV8, BPE IO-360, C/S
5yr build, 10yr Flying
Still Grinning!
Dues Pd
Old 06-30-2017, 11:05 PM
Thanks guys for the input. I don't see anything in the plans for a "cover" back there but I sure do what to find a way to close up the center tunnel, if not my 4-year old is going to fill it up with Matchbox cars and Cheerios. It sure does look like its going to take one big boot back there to make it work. Maybe I will make an aluminum raised cover with a smaller boot then at the top. Rod the strap was built to allow me to move my seat all the back to that point as I'm 6'4. It started out as a 5lb block of aluminum and 8hr later in a CNC it weights a few ounces.
Thanks Again guys!
Old 07-01-2017, 03:45 AM
WAM120RV WAM120RV is offline
Default Fabricate
Hi
This is an area where you need to fabricate something . I used 25 though sheet.
From the photo it looks like the torque tube is pulled up a bit high because if the bracket holding the rise joint.
There is a photos of this area on my build blog On the first page, just click on the blog link.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 07-01-2017, 06:54 AM
brad walton brad walton is offline
Don't forget about back seat air that comes up in this area also
Old 07-01-2017, 08:08 AM
Originally Posted by WAM120RV View Post
Hi
That's exactly what I'm thinking I need to build. Thanks for the link and pictures. I agree it seams I have that rod end to high in the brace but the the plans show 1" from center of rod end to the top of the mounting plate and the factory mount plate is spaces up with 3/4 stock so I set my rod end to -.25" below the floor. Does this sound correct? Maybe I need to recheck as I do have a lot of treads sticking up and my brace is 3/4" tall at that center point.
My plan for backseat air is a NACA duct in the bottom of the wing so I will put an air vent in the floor just outside of the center tunnel. My front tunnel is a smoke tank so I have no way of getting scatt tubing from front to back.
Thanks again for the help guys.
Old 07-01-2017, 08:00 PM
Default what I did
I have been down that road when I built mine. I have lots of pictures, and many are already on threads here. I have a fully closed aluminum cover,leather boot, and fresh air vented from the bottom of the right wing ,through the tunnel and into the rear stick console. It's easier to send pictures to an email than post on here (for me). You need to have the front seat mounted to set your for and aft stick position at optimum angle.
Bill E.
RV-4/N76WE
41 Aeronca 65TC Defender
8A7 / Advance NC
Old 07-02-2017, 09:15 PM
Tomcat RV4 Tomcat RV4 is offline
Dont know how they will work ,as about to start flying,but installed 4 rv10 vents,2 front,2 for rear.Tomcatrv4
Tomcat RV4
dues paid and worth every penny
