Old 06-30-2017, 07:56 AM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
Default Engine Start without wings on?
I know you should never start a big bore Lycoming on a not fully assembled RV due to shaking dynamics. Anyone have experience with the small bore smooth running Rotax? Helping a friend do ALL the SBs and Rotax replacements on an older plane that has not been flown in about 5 years. With most all done he is itching to run the motor at his shop before painting to validate all the updates and replacements. I know it is not much work to reinstall the tail and wings but there is not enough space.
Scott- 2018 dues paid
Got medical back, now building a 7A.
RV-12 #120515, 319RV over 200 hours.
1st flight 12/08/15, flew SNF, Oshkosh, Triple Tree & SERFI in year 1!
RV-9A, 536 hours, sold, RV-7 sold, Kitfox sold
Old 06-30-2017, 08:09 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Have you asked Van's? I'd like to hear what they say about this, or perhaps they've already addressed it.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
N79599/APRS Automatic Position Reporting System
“Certainly, travel is more than the seeing of sights;
it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
"It should be added that the sublime beauty of the facture brings within the realm of discourse the substructure of critical thinking. " -using Doug's Art Critique jargon link and my birthday, I get this!
Old 06-30-2017, 09:33 AM
mike newall's Avatar
There isn't any way a Rotax is going to torque it over on it's side, but the normal precautions of tie it to something substantial with a suitable robust rope or cable and don't rev it's nuts off.
We ran our 7 like that to check systems, leaks etc etc and am glad we did - found an ignition issue that could be fixed at the shop, not easily at the field.
As with anything, prep, check, ask yourself is it safe, don't let it lead to a Darwin event
Finally, if it does, make sure you have video and get your $250
Donated in 2017
Old 06-30-2017, 09:37 AM
Rrhsch Rrhsch is online now
I tied mine down to a tree with wings off. I didn't have a problem.
Old 06-30-2017, 09:56 AM
That is what we were considering. I did the same for my old Kitfox for a full Rotax 2 cycle engine breakin. I was thinking that since the 12 has the structural wing box beam the fuselage is at full strength where the other RVs need the wing spar bolted in to complete the fuselage structure. Just planning a short run probably just to 2500 rpm to validate ignition and fuel systems.
Old 06-30-2017, 10:28 AM
rv7boy's Avatar
Forum Peruser
I remember Bob tied his 6A to a couple of stakes and maybe a tree when he tested that engine. But he did have the wings on.
Don't forget the fire extinguisher! We had no fires but I was ready just in case. 😀
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 06-30-2017, 10:34 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
I tied the plane to the car:
https://www.youtube.com/watch?v=BRMHWbpxsPc
PH-BZT
MyKitlog
Picasa pictures
Old 06-30-2017, 11:49 AM
The reason it is not recommended on the other RV models has nothing to do with fuselage strength (and it is not because of a fear of it rolling over). It is because of the inertial damping in roll that the wings provide.
The majority of the shake induced by a Lyc. is in roll. Without wings installed, there is much less mass to limit the shake.
There are documented cases of RV's having elevators and rudder damaged because of an engine start/shut down without wings installed.
Can it be a problem with an RV-12? Probably not, but I cant' say for sure because we choose not to take the chance.
Scott McDaniels
Hubbard, Oregon
Old 06-30-2017, 12:47 PM
DBRuth DBRuth is offline
Default No wings start
I have run mine three or four times without the wings on to sync carbs or warm the oil prior to changing. Always chock the mains and use a strap on the tail tiedown to my truck. Nothing has fallen off yet.
N412DR
Kit 120797
First flight 8/21/15 what an awesome aircraft!
HOBBS @129.3
Old 06-30-2017, 01:22 PM
funflying funflying is offline
I too ran mine without wings like the prior post, and had no problems but was cautious. No taxing or full power run ups and nothing felt unsafe or being over stressed.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
