Old 06-29-2017, 06:33 PM
mgregory176 mgregory176 is offline
Default Mounting the EFii coil pack
Can any fellow Efii users send me some pics of how you mounted the coil pack? The packs are mounted on the Efii bracket and I am thinking the best place is on top of the upper cross bar on the engine mount. I have found a couple of pics of others who have placed it in this location but I can't find any pics of how they attached it.
I'm open to other suggestions as well.
-Mike
Mike Gregory RV-10
Working on the fuselage
Clayton, DE
http://www.mykitlog.com/mgregory176
I'm better at building than updating the website
Old 06-29-2017, 07:25 PM
skidookid skidookid is offline
Default Coil mounting
I believe EfI has a coil pack mount for top of engine case.
Old 06-30-2017, 07:02 AM
sritchie sritchie is offline
They do, but I'm with the poster... I haven't found any clear pictures of how people are actually attaching the mount onto the engine mount!
I know some folks have used U-bolts (is that what they're called?) and I believe I've seen zipties as well. I can't quite square it away in my head with the locations of the holes in the mounting plate.
Old 06-30-2017, 09:52 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
I don't have any clear pics of the attachment, but I used U bolts. 130hrs and it hasn't budged. The holes line up perfectly. Just experiment a little. I know others have used adel clamps. I think I was the second one to use this mounting location. I copied another guy
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
Old 06-30-2017, 03:18 PM
Dustyone Dustyone is offline
Default Adel clamps with centre brace
While not an EFII coil pack,I also wanted my coils mounted up high on the centre brace.
I made my own bracket,write up here,
http://www.vansairforce.com/communit...d.php?t=140051
I used the 4 x adel clamps, two at each end . I also added a centre brace to the diagonal cross brace using a 30 mm stand off. This centre brace stopped any fore/aft rocking moment. So you end up with a solid mount that is not touching the engine mount.
For SDS CPI users, I converted my design to CAD and Ross now sells these via his web site when you order through him,
Ashley Miller
RV-10 #40597
Airflow Systems Air-Con
http://www.vansairforce.com/communit...4&postcount=15
VH-XTE 400hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
Old 06-30-2017, 08:28 PM
Default here
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 07-04-2017, 04:03 PM
Default Mounting efii coil pack
Thanks! This is exactly what I needed to see. I really like the back brace to the angle. Stabilizing the rocking motion was one of of my concerns with mounting it in this location
Mike Gregory RV-10
Clayton, DE
