Old 06-29-2017, 11:34 PM
epaslick's Avatar
epaslick epaslick is offline
Originally Posted by joedallas View Post
This subject is one of many opinions.
If I was building in a small place I would built the wings after the fuselage is complete and engine is installed.
You can roll the aircraft outside and work on the wings or take the aircraft to the hanger and build the wings at home.
My View
Joe Dallas
Are you suggesting Empennage -> Fuselage -> Finnish Kit and THEN Wings?
My understanding is the gear, wheels and engine mount are part of the Finnish Kit. You can't mount the engine and roll it without those...
Eric Paslick
EAA Chapter 732
Siloam Springs, AR
RV-12 #120991
Empennage: Started
N62EP Reserved
2018 Donation Made
Old 06-30-2017, 06:30 AM
joedallas's Avatar
joedallas joedallas is offline
Default Wings Last
Yes
Empennage -> Fuselage -> Finnish Kit -> Engine -> Avionics and Then the Wings.
Or Empennage and Wings Last
Finish the complete Fuselage then the wings.
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 06-30-2017, 06:41 AM
tomkk's Avatar
tomkk tomkk is offline
If I were going modify the order for build space reasons I guess I'd get both the Fuselage and Finish kits together. Most of the parts are relatively small and easy to store except the canopy, rear window and cowling. That represents a huge amount of the build. Then I'd add the Engine and Avionics kits. I'd probably do the Wings next to get the Flapperon linkage in the aft fuselage right and the Empennage last.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845
First flight 06/10/2015
Old 06-30-2017, 09:20 AM
joedallas's Avatar
Default update coming ?
This may be ok if he is a quick builder, however the finish kit may have updates if he waits until he finishes the fuselage kit.
I think there is a change in the wiring harness update coming if he is to use Garmin avionics .
This change may even effect the Empennage kit.
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 06-30-2017, 09:40 AM
tomkk's Avatar
Joe Dallas
Yeah, that's true. At least for me, the Fuselage & Finish kits were about 25% each of my total build time. Van's shows the lead time for both of those is about 8 weeks. I guess you could use that to estimate when to order the Finish kit so it would arrive near the time it was needed in the build sequence.
Tom
Port Orange, Fl
