Old 06-26-2017, 08:00 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Help with control tube install ?
The print calls for a 2 5/8 x 4 1/2 rectangular hole in the bulkhead sheets at the spar. The control tube will not pass through. Before I start HACKING, what am I missing ????
Larry DeCamp
RV-3B flying
RV-4 fastback project in the shop
Clinton, IN
Old 07-09-2017, 09:37 PM
ESPRV4 ESPRV4 is offline
Default Control tube installation
Hi Larry
I remember the same issue on my -4 (2004 kit ). From memory the steel control tube supplied is from an RV8 so the dimensions are a little larger than the early model-4's. I remember very slightly increasing the size of the hole in the web of the main spar , so as to get the control tube through, but it was still tight. !
Hope that helps.
David Taylor
0-320 RV4
Myrup WA.
ESPRV4
Old 07-09-2017, 10:23 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Originally Posted by ESPRV4 View Post
Hi Larry
Hope that helps.
David Taylor
0-320 RV4
Myrup WA.
No that's not the case, the RV4 came first and the RV8 uses some of the same parts on the control column but they are not the same part/weldment and not interchangeable. As to fitting either one of these through their prescribed hole in the spar, I don't know, I've never been there myself.
Russ McCutcheon
www.mccutcheonmetalfabricationaviation.com
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 07-09-2017, 10:25 PM
On my -6, I remember having to slightly flex the elevator pushrod to fit it through the pass-through in the rear spar.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 07-09-2017, 10:59 PM
BruceMe's Avatar
BruceMe BruceMe is offline
Check the geometry carefully, you can swap things around easily and it will be off enough to look dead wrong. If you get everything right, it should fit with only minor trimming.
Pictures?
-Bruce
Bruce Meacham
Built/Own RV-4 254MM
Owned RV-6 4074V
First RV RV-3 3456B
VAF annual donation on autopay
