Old 06-25-2017, 03:25 PM
Freightdawg's Avatar
Freightdawg Freightdawg is offline
Default Section 36 Brake Lines
I'm already off to a bad start, which is to say no start at all.
Step 1: enlarge the brake line exit hole in the bottom skin to 5/8 as called out in fig 1.
Glad that was already done before the gear mount was in place.
Step 2: Install the fitting...
But the fitting doesn't fit. Surely Vans didn't mean to enlarge the hole in the gear mount to 5/8 also. I'm guessing it needs to be enlarged to 7/16 since it's a -4D fitting(?)
Am I missing something?
Jeff Rich
RV-10 empennage done for now. Wings done for now. Working on the (SB) fuse (Section 43: Cabin Cover)
Finishing Kit is here! Check for the motor cleared
N313KC reserved
In the garage for now, KJVY this summer
Old 06-25-2017, 04:12 PM
Flandy10 Flandy10 is offline
I went back and read the instructions and looked at my pictures.
Yes, you have to enlarge the hole in the gear mount so the bulkhead fitting will slide through the two concentric holes. If it helps, measure the diameter of the bulkhead fitting to verify the needed hole size.
Scott Flandermeyer
Rv-10 TDI #40816
Fayettevile, GA
2018 VAF Donation complete
Old 06-25-2017, 06:31 PM
Default Same
Yep I did the same and as you found out 5/8 is to big...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 07-05-2017, 01:48 PM
rapid_ascent rapid_ascent is offline
It took me a little while to figure out what they intended, at least on the RV-7A. The idea is that the bulkhead fitting sits on the landing gear mount. The hole in the bottom skin is just a clearance hole. On the 7A there is a gap between the bottom skin and the gear mount that is what had me confused.
I did eventually see the larger hole callout on the drawing for the 5/8" hole. I drilled one hole this way, but I had a issue where the hole in the bottom skin wasn't perfectly aligned with the hole in the gear mount.
I think the better way is to work up to the larger hole in the skin. Start with a hole that the bulkhead fitting can pass through then use a little (3/8") sanding drum on a dremel tool working up to a larger (1/2") drum to get the clearance that you need. This approach worked well for me. I assume I'll be filling around the fitting with sealant of some kind later on.
Hope this helps.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 07-26-2017, 11:50 AM
Thanks all.
(It's been a little while since I've been on.)
Jeff Rich
N313KC reserved
